Funny Rail Revolve
All  1-6  7-10
94.7 In reply to 94.6
Yeah, at first I tried enabling history on everything by default. But several things such as copy and mirror could have pretty surprising results. So I couldn't really turn it on for everything by default.
But I thought that I would turn it on by default for these commands: Extrude, Revolve, Rail Revolve, Sweep, Blend, Offset curve, Planar curve, and Loft.
These seem to be ones where a lot of people are expecting history to work on, so I wanted to make it work automatically here, instead of having to manually turn it on for these.
It can still be a bit surprising if you're not thinking about it when you move the original curves around, though.
94.8 In reply to 94.7
It seems that when i click history with no objects selected, it pops up the extrude tool's dialog (select curves...to extrude), i'm assuming this is an error. Functionally there is no problem.
Michael H.
94.9 In reply to 94.8
< it pops up the extrude tool's dialog (select curves...to extrude)
Same thing !
94.10 In reply to 94.8
Yup, it is a typo in the command UI.
Thanks for reporting it, it's fixed for the next beta release.
Show messages: All  1-6  7-10
