New Beta
 1-6  7-26  27
9397.7 In reply to 9397.5
Hi eric, it's really close! I keep finding areas for dimensions where I was going to cut corners but instead I've gone ahead with more functionality.
Like I was going to originally have only screen-aligned text, but now I've got an option for either screen aligned or dimension aligned text.
I was going to have just one basic arrowhead, but now I've got a choice between Arrows, Ticks, Open arrows or dots.
I was going to have everything in the same font but now there can be different fonts.
I was going to have just single lines of text but now I've got support for multiple lines of text.
So it has taken some additional time to flesh out each of these areas but I think it will be worth it since it will be much more likely that they will be useful for you.
Here's what it looks like at the moment:
They are very close to being functional. Some of the main remaining areas are implementing UI for controlling these different options and also setting up the commands for drawing them at the moment they are only loaded from .3dm files made in Rhino.
9397.8 In reply to 9397.6
Hi Terry,
> I'm wondering how much control there will be for adjusting precision - decimals and fractions??
Well I was planning on having settings similar to the UI precision options currently under Options > General > "Decimal display" and if you are using feet or inches units you should be able to choose between decimal display or feet & inches display with fractions. But I probably won't have a general fractional display separate from "Feet & Inches" for now.
9397.9
Thank you Michael. I like what you are doing. Do you know yet at what level of precision fraction will be displayed - 1/8", 1/16", 1/32"...?
9397.10 In reply to 9397.7
Hi Michael ...
Thanks for all the extra effort you are putting into dimensions. It looks awesome and well worth waiting for.
cheers,
eric
9397.11 In reply to 9397.9
Hi Terry,
My plan for "feet & inches" dimensions will be that you can choose the precision same as you do for the MoI UI under Options > General :
There will be a default value that you can set for what newly created dimensions will start out as and you'll be able to change it on individual ones.
9397.12
That sound perfect.
12345
Text
TextBlock
Can we center that all group ? (don't shown on your images)
9397.14 In reply to 9397.13
Hi Pilou, yes on multi-line text there is going to be an option for alignment: left, center, right, or justified.
Here's what it looks like with center alignment:
9397.15
Cool stuff!
Perfect!
9397.17 In reply to 9397.16
Really good stuff Michael !
9397.18 In reply to 9397.17
I would ask you only, if it is possible to align the dimension description/text above the line like in technical drawings ( https://en.wikipedia.org/wiki/Technical_drawing#/media/File:DIN_69893_hsk_63a_drawing.png ) ?
Thank you,
Mik
9397.19
Wow, that's great news!
Blocks of text will be very useful.
Marc
9397.20
Really cool stuff! Thanks for all the hard work Michael!
9397.21 In reply to 9397.18
Hi Mik,
I don't have that one set up quite yet to show off but it is planned.
9397.22 In reply to 9397.21
Thank you, Michael, it would be great.
Mik
Something like that is possible ?
9397.24 In reply to 9397.23
Hi Pilou, no the new annotations won't be for doing something like that, you would need to use other drawing tools (like Draw Solid > Text and Transform > Deform > Flow) to make that type of thing.
Do you have any examples of technical drawings that have a wiggly shape like that?
9397.25 In reply to 9397.24
For more versatility...
It was more purpose for graphic design objects image!
for take advantage of the possibility to draw anything in 3D or 2D! ;)
Of course Flow function can supply of that...but if it's will be in native that will give a little unic speed feature to the prog! ;)
As you draw a straight curve (?) for dimension I could believe that will be automatic to draw a sinuous one :)
EDITED: 5 Jul 2019 by PILOU
9397.26 In reply to 9397.25
Unfortunately no - it would take a lot of additional work to make dimensions able to do that it is very far from being automatic.
Show messages:  1-6  7-26  27
