New Beta
 1-10  11-27
9397.11 In reply to 9397.9
Hi Terry,
> Do you know yet at what level of precision fraction will be displayed - 1/8", 1/16", 1/32"...?
My plan for "feet & inches" dimensions will be that you can choose the precision same as you do for the MoI UI under Options > General :
There will be a default value that you can set for what newly created dimensions will start out as and you'll be able to change it on individual ones.
9397.12
That sound perfect.
12345
Text
TextBlock
Can we center that all group ? (don't shown on your images)
9397.14 In reply to 9397.13
Hi Pilou, yes on multi-line text there is going to be an option for alignment: left, center, right, or justified.
Here's what it looks like with center alignment:
9397.15
Cool stuff!
Perfect!
9397.17 In reply to 9397.16
Really good stuff Michael !
9397.18 In reply to 9397.17
I would ask you only, if it is possible to align the dimension description/text above the line like in technical drawings ( https://en.wikipedia.org/wiki/Technical_drawing#/media/File:DIN_69893_hsk_63a_drawing.png ) ?
Thank you,
Mik
9397.19
Wow, that's great news!
Blocks of text will be very useful.
Marc
9397.20
Really cool stuff! Thanks for all the hard work Michael!
9397.21 In reply to 9397.18
Hi Mik,
I don't have that one set up quite yet to show off but it is planned.
9397.22 In reply to 9397.21
Thank you, Michael, it would be great.
Mik
Something like that is possible ?
9397.24 In reply to 9397.23
Hi Pilou, no the new annotations won't be for doing something like that, you would need to use other drawing tools (like Draw Solid > Text and Transform > Deform > Flow) to make that type of thing.
Do you have any examples of technical drawings that have a wiggly shape like that?
9397.25 In reply to 9397.24
For more versatility...
It was more purpose for graphic design objects image!
for take advantage of the possibility to draw anything in 3D or 2D! ;)
Of course Flow function can supply of that...but if it's will be in native that will give a little unic speed feature to the prog! ;)
As you draw a straight curve (?) for dimension I could believe that will be automatic to draw a sinuous one :)
EDITED: 5 Jul 2019 by PILOU
9397.26 In reply to 9397.25
Unfortunately no - it would take a lot of additional work to make dimensions able to do that it is very far from being automatic.
9397.27 In reply to 9397.26
No problem the "Flow" will make the trick! :)
Show messages:  1-10  11-27
