NETWORK CURVES non pinch surface
All  1-5  6-12
work in mm don't increase some problems of decimal point capacities or number of digits acceptable ?
not more easy to work without unity and transform at the end if needing?
9390.7 In reply to 9390.6
Hi Pilou, the current unit system doesn't really have any effect on decimal point accuracy, unless it also causes you to use large or small numeric values.
For example if you make a line and put in a coordinate of x = 4.0 y = 3.0 for the start point of the line, the line will have those numeric values x = 4.0 and y = 3.0 no matter what unit system you have set.
The unit system is more like an additional label that says to someone how those numeric values are supposed to relate to real world measurements.
That's how it works in MoI anyway, it is true that some programs do it differently like SketchUp I think translates everything you enter into inches I think. That can then cause some problems like you are asking about.
But MoI does not alter numeric values that you enter unless you ask it to by giving a different unit system at the end when you type in a coordinate.
9390.8 In reply to 9390.7
ok :)
how many significant digits can be admissible ?
7 max in the right decimal point box
how many in the left part ?
9390.9
How did you get to show the control points?
Yes in creating the flow deformation I usually copy and past the target surface and flatten that down to 0 depth and use that as the base mapping surface so in theory should be same size.
I just tried it by same process but I offset reduced the base surface and then used the flow command and then boolean difference and it all worked smoothly - thats another great tip.
9390.10 In reply to 9390.8
Well it's a bit complicated, there is not really a fixed limit on that.
The way floating point mathematics works on the computer allows for a floating point number to have a very wide range of values but larger values have less precision. Also precision is greater the closer you are to the origin.
To keep things the most robust and avoid arithmetic precision problems it's generally good to keep numeric values say not larger than 5000 and not smaller than say 0.05 or so. But those are not hard limits.
9390.11 In reply to 9390.9
Hi Alex,
They'll show up if you turn on points and then do a "Select all". The extreme size probably messes with the depth buffering in the regular display.
9390.12 In reply to 9390.10
Perfect !
EDITED: 10 Jun 2019 by PILOU
Show messages: All  1-5  6-12
