Best way to select edges curves?
All  1  2-4
9385.2 In reply to 9385.1
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
Copy above on the second column of shortcut! ;)
9385.3 In reply to 9385.1
Hi ColoristNow, also if you select one edge then you can do a selection window drag which will then target edges.
If you have an example model where you're having difficulty selecting edges if you could post the model file I may be able to give some suggestions.
9385.4
Thank you very much for the help, have a nice day!
Show messages: All  1  2-4
