Tangent Circles on a curve
All  1-9  10-12
The circle tangent command relies on picked points to determine which particular circle to make, in many situations there are multiple possible tangent circles.
But because it uses picked points it is not easy to automate this particular command unfortunately.
An automated one would probably need its own custom solver.
9381.11 In reply to 9381.10
So maybe a Scale Array of circles can make a cool approximation in just change the actual method of regular increase/ decrease ?
Mixed with the Array on Curve in just change the actual method of regular propagation...(same coef) here 0,7 for my first example
We draw only the 2 first tangent circles for calculate this coef !
Seems it's not a too difficult changement of the existing methods! :)
EDITED: 28 May 2019 by PILOU
9381.12 In reply to 9381.11
Using some simple trigonometry:
If theta is half of the angle between the two tangent lines, then the scale between adjoining radii for shrinking circles, is = (1-sin(theta)) / (1 + sin(theta)).
For the next largest circle, the formula is the reciprocal.
There are also Steiner chains, Pappus chains, and Ford circles.
Using sine of the angle to calculate the location of the first radius did cause some rounding, like a radius of 10 going to 9.999999... or so, which I did not care for :-)
EDITED: 14 Jun 2019 by BEMFARMER
Show messages: All  1-9  10-12
