Cutting model based on camera angle
All  1-3  4-6
9364.4
Oh, is it also possible to disable perspective in 3d mode? basically make it an ortho 3d view?
9364.5 In reply to 9364.4
Hi Nebuka, yes there is a setting for disabling perspective in the 3D view under Options > View > 3D View projection. Set it to 3D view projection: Parallel.
That will modify the 3D viewport for the current file. If you also want it off by default when you first start MoI, save off a .3dm file with it set how you want and then put in that .3dm file as the startup template under Options > General > "Template file".
9364.6 In reply to 9364.5
perfect, Thanks Michael
Show messages: All  1-3  4-6
