Cutting model based on camera angle
All  1-2  3-6
9364.3
This is awesome, Thanks a lot Michael.
9364.4
Oh, is it also possible to disable perspective in 3d mode? basically make it an ortho 3d view?
9364.5 In reply to 9364.4
Hi Nebuka, yes there is a setting for disabling perspective in the 3D view under Options > View > 3D View projection. Set it to 3D view projection: Parallel.
That will modify the 3D viewport for the current file. If you also want it off by default when you first start MoI, save off a .3dm file with it set how you want and then put in that .3dm file as the startup template under Options > General > "Template file".
9364.6 In reply to 9364.5
perfect, Thanks Michael
Show messages: All  1-2  3-6
