Any parametric updates?
 1-17  18-37  38-57  58-77  78-97  98-113
9363.58 In reply to 9363.55
Michael,
I greatly appreciate the efforts you have gone to on this.
Maybe Karsten's solution then is the best way to go, but only if his cone arrowheads could be made to be scale independent (ie always small).
Another possible work around would be to have 2 perpendicular associated planes with each vector, like shown below, however with only one arrow displayed at any one time. The display would be triggered on/off (or off/on) based on angle of incidence to screen view.
Again thanks you so much for looking to solve this
PS the work you have done to date for display "flat to screen" will find utility with the "Numbering" node
9363.59 In reply to 9363.57
> I guess several MoI drawings would need to be combined in pdf?
Something like that would really need some other software rather than MoI. The new dimensions in MoI will be useful for simple cases and light duty but not really for making detailed production drawings like that example.
Various other CAD software have a much more extensive drawing toolset to help make that type of output.
Can we move, orient (align) , size the "Blah" text ? (after draw the arrow lines)
Does the "Blah" text has some of these 3 functions as "native" ones when you draw the arrow lines?
and something like "out" (begin, end) "cut" (when inside) arrow lines?
EDITED: 28 May 2019 by PILOU
9363.61 In reply to 9363.60
MOI + Make2D4Views script ( http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1 ) exported in DXF + free SOLID EDGE 2D DRAFTING ( https://www.plm.automation.siemens.com/plmapp/education/solid-edge/en_us/free-software/free-2d-cad ) = perfect results for technical drawing.
Only thing it has to be done is alignment of views according to appropriate standard - US vs EU ( http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.19 )
Ciao
Mik
9363.62 In reply to 9363.61
even simpler....
MOI + ONSHAPE (free)
Import my MoI .3dm file in Onshape and apply Menu > Create drawing of 3dm
9363.63 In reply to 9363.60
I'll probably try to have an option for moving it but align or sizing is not likely.
Sorry I don't understand this part.
I'm going to be working on having text cut the arrow line, the text part is still not finished yet.
9363.64 In reply to 9363.58
Hi James,
I gave this a try, here's what it looks like:
Doesn't seem too satisfying in removing planar feel to it, if you pause the video at various spots things still seem pretty planar.
9363.65 In reply to 9363.64
Michael,
On the contrary, I think it is most satisfactory. Vectors after all are just aids for visualising spatial constraint in the construction process; not for final output.
Thank you so much, brilliant work
9363.66 In reply to 9363.65
Hi James, ok well it's a quite localized tweak to get that behavior so it should be fine to have a script property on annotation objects that will make it behave like that when set.
Those ones shown in the last video are Leader objects with 2 points.
9363.67 In reply to 9363.63
<< Sorry I don't understand this part.
When you draw your "arrows" does the Text is yet configured for have definited Size, Align (up, down,on), Distance etc... or it's after draw?
Or we can take the "Blah" as an normal object for make any what you want...
But I am not impatient! :) Because there is yet a cool one by Max Smirnov! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7403.133
9363.68 In reply to 9363.67
> When you draw your "arrows" does the Text is yet configured for has definited Size, Align (up, down,on),
Neither - the text is displayed as a text label on screen more like the object snap tags like "End", "Mid", etc... so it gets its size from the regular UI font size.
9363.69 In reply to 9363.56
Thanks, the extension lines would be fine with that gap.
>For the gap on arrows, would that also apply to the arrows going to the extension lines in a linear dimension like above,
>or only to the arrows on other dimension types?
The arrows can touch the shapes and the extension lines as there is no ambiguity for the reader but the actual ones slightly cross the shapes.
Michel
EDITED: 28 May 2019 by VINC
9363.70
When will we get the dimension tool. I think everybody here is full of expectation.
9363.71 In reply to 9363.69
Hi Michel, the arrowhead points do have a few pixels sticking out past the lines, that's due to its wire outline being drawn with mitered corners and anti-aliasing.
You can see the same thing in regular curves in MoI if you just make a line and a pointy triangle:
Max's one doesn't do that because it makes a surface for the arrowhead and surface trim boundaries are not drawn with mitered corners between segments.
If this is troublesome I guess I could make a setting to not miter the arrowhead tip.
9363.72 In reply to 9363.70
Hi Rudl,
It will be in the next v4 beta which will probably be the last one.
I've got just a couple more areas to finish them - text display and export to PDF/AI/DXF formats.
9363.73 In reply to 9363.71
Thanks for the explanation.
I would prefer the drawing to be as sharp as possible when adding dimensions if it's not too hard or heavy on display performance.
Michel
9363.74 In reply to 9363.65
Hi James, here's a different variation on the arrowhead reorienting. This one turns the plane around the arrowhead direction to point as much as possible towards the view direction.
I tried this before but I guess I had something wrong. What do you think, better or worse than the one that switches between 2 planes? :
9363.75 In reply to 9363.74
Michael,
>> better or worse....? <<
Not just better, it is exactly what I originally requested.
Absolutely Brilliant!
Thank you so much
9363.76 In reply to 9363.73
Hi Michel,
Well the thing is that mitered corners for the outer line drawing helps make the butt end of the arrow sharp.
It's subtle but here's a comparison - here's #1 with all mitered corners for the outer line:
Here's #2 with the outer boundary as separate lines with no mitered corners at all. The thing I don't like here is if you zoom in to the butt of the horizontal ones you can see it's got a slight rounded appearance instead of very crisp corners:
Here's #3 with only the butt corners mitered and not the tip mitered. It makes a little more blunt tip than it ideally should be but that would also mean the tip won't stick out as much:
Here's #4 with no outer line drawings at all, only a fill:
So number 1 is pretty much the best arrowhead shape that I can make I think. I don't like the butt end of number 2. Number 3 seems like a good compromise it keeps the tip from extending out too much but keeps the butt end sharp. The tip is a little rounded from a perfect arrowhead though. Number 4 seems pretty gross with no antialiasing.
My current thinking is that I'll go with #1 by default but I could have an option to do #3 instead. I'm not sure if #2 or #4 have much value but let me know what you think.
9363.77 In reply to 9363.75
Hi James,
That's great, you're welcome! That's what I'll set up then.
Show messages:  1-17  18-37  38-57  58-77  78-97  98-113
