Any parametric updates?
 1-5  6-25  26-45  46-65  66-85  86-105  106-113
9363.46 In reply to 9363.44
Hi Marco,
> I'm talking about some new modelling tool like for example "Cage deformation", "Bending and tapering"
> (beyond the "flow" tool), some surface continuity tool, a Zebra checker, Instanting and Grouping
> (long...long awaited)
> Just to name a few.
These have been requested by quite a few people so it's pretty likely they will become a part of MoI at some point. But it won't happen for v4 and I cannot promise which specific version they will show up in.
If any of these are very important functions for what you need to do, there is other software out there that does all of these things like Rhino for example. So if you need these things now it would make sense for you to use other software that does what you need instead of MoI.
9363.47 In reply to 9363.44
"I'm talking about some new modelling tool like for example "Cage deformation", "Bending and tapering" (beyond the "flow" tool), some surface continuity tool, a Zebra checker, Instanting and Grouping (long...long awaited)
Just to name a few."
Well, like I said, use MAX for that.
(PS: You can group by assigning the same Styles to different objects, then you select them as a group by just clicking that style. Instancing is only necessary to save calculation power and ram, both of which are not so much of an issue nowadays and doesn't help if the renderer/model format don't support it. Besides, some renderers allow instancing right within them. Normals I usually set up in the renderer, triplanar being the quick and easy way out (zebra eliminated), continuity is using Blend etc. correctly, you can taper using 1d scaling and bend using flow.)
Of course things like this will prob. be added eventually under the menu commands I am sure. But until then I got all I need so far.
You might want to get back into MoI and with a bit of re-thinking the mesh modeling flow (i.e., ditch it) you might just fall in love with it again...
There was a post here with 3 articles from a German magazine which showed how powerful and easy MoI modeling is. That guy created cool models with a minimum of curves and solids. Definitely worth reading.
One thing I learned: If I wait for my favorite tool to become what I really want it to be, I'll never use it, because there's always another feature one can wait for.
9363.48 In reply to 9363.46
Hello Michael.
@You: "...it would make sense for you to use other software..."
Ok. I didn't want to start and endless conversation about this topic here so let's stop here this conversation :)
THANKS ANYWAY FOR YOUR KIND REPLY. AS USUAL :)
But evidently I didn't make my point clearly enough or you didn't understand what I wanted to say.
No problem.
As I've said TONS AND TONS OF TIMES, I still consider Moi one of THE BEST fast and quick 3D Nurbs modeler, thanks to its super streamlined workflow.
And I'M NOT QUITTING MOI.
But for a long long time (except for 64Bit and the latest SubDiv tool) it didn't receive a TRUE UPDATE about new modelling tools.
This is a fact.
Have a nice day a best wishes for your job and your things in general :)
Ciao.
9363.49 In reply to 9363.20
Michael,
It is indeed exciting that dimensions are coming to Moi3d.
These scale-independent arrows and numerals will also be beneficial to vector nodes and to the numbering node, respectively.
I have looked at your video, and see that the arrow head remains in the plain of the dimensioning; which makes sense.
Would it be possible to have a script option for arrowhead display to in alignment with the screen view, because vectors
are not tied to a plane? Does that make sense? Karsten has achieved this by making the arrowhead a 3D solid element, but your new arrowheads would be a more elegant solution IMHO.
If this is too much trouble, please disregard; I just thought it was better to ask earlier rather than after dimensioning had be finalised.
9363.50 In reply to 9363.49
Hi James,
> screen view, because vectors are not tied to a plane?
I think it could be possible, I'll experiment with it and see.
The way the annotations work is there will currently be 5 different types of objects for them: Linear dimension, Radial dimension, Angular dimension, Leader, and Text.
They all have a plane associated with them, but if you make a leader with 2 points you could have its plane be any plane containing those 2 points and that would give you a line with an arrowhead on one end of it. Does that sound like it would work for that if there was an additional property to show an annotation's arrowhead flat to the screen?
9363.51 In reply to 9363.50
Michael,
>> Does that sound like it would work for that if there was an additional property to show an annotation's arrowhead flat to the screen? <<
In the case of text for numbering node it would be ideal to be always displayed "flat to the screen"
However, I'm not sure that I explained myself well in regards to arrows.
Have a look at this image: https://i.ytimg.com/vi/bFzZB4zhqLo/maxresdefault.jpg
or alternatively starting at 13:01 on this video: https://vimeo.com/49043607
The arrows are not "flat to the screen" but are oriented along the vector, yet nevertheless, rotated so that arrowhead is always face on.
I hope this is clearer
9363.52 In reply to 9363.51
Hi James, so what I meant by "flat to the screen" is having an arrowhead drawn as if it was in a 2D vector program, like it's always the same proportions just rotated only in the screen plane like these:
So all those arrowheads above all have the same area of filled pixels on the screen.
But that video you linked to makes me wonder if I'm not getting the right idea since it shows some arrowheads that appear to have different proportions and filled areas like here:
But the image you linked to looks like all the same pixel filled area like in the first image above...
9363.53 In reply to 9363.52
Michael,
>> But the image you linked to looks like all the same pixel filled area like in the first image above... <<
Yes that image was a poor choice because the vectors are on the same plane, and hence there is no foreshortening of vectors viewed head-on (or tail on).
Below is Karsten's existing solution for vector display. Although it works well, the arrows are not scale-independent & so an arrowhead may obscure much of the model if viewed closeup & head-on.
Your dimension arrows (as shown in your video) would be suitable except a vector is one-dimensional not tied to a plane.
Perhaps this is more difficult then first thought.
Thanks for looking into this
9363.54 In reply to 9363.53
To avoid possible confusion with visible lines when printing screenshots in black & white, do you think you'll be able to insert a small gap between dimension elements (extension lines, arrows) and objects?
I really like those arrows.
Michel
9363.55 In reply to 9363.53
Hi James, ok I think I understand better now - you don't want a 2D type screen facing arrow, you want one with perspective foreshortening but that does not look like it is in a fixed plane.
I experimented with a couple of things for that but could not come up with a good result, the current approach is pretty focused on a planar looking type shape.
9363.56 In reply to 9363.54
Hi Michel,
> and objects?
So something like this for the extension lines? :
For the gap on arrows, would that also apply to the arrows going to the extension lines in a linear dimension like above, or only to the arrows on other dimension types?
I'm not sure if I'll be able to do an arrow gap on angular dimensions because that would also involve trimming back some of the arc that is being drawn, but I could do it for radial and leader dimension types.
ecabinetsystems has some discussion about 3D dimensions here:
http://order.ecabinetsystems.com/updates/ecabinetsystemsmadeeasy/Dimensioning_in_3D.htm
They use red dimension lines with blue arrows for 3D, but do have some warnings about confusion.
I particularly liked the drawing and anatomy at this link:
https://www.3dhubs.com/knowledge-base/how-prepare-technical-drawing-cnc-machining
I guess several MoI drawings would need to be combined in pdf?
The link "angle projection" goes to "Multiview projection-Wikipedia."
EDITED: 27 May 2019 by BEMFARMER
9363.58 In reply to 9363.55
Michael,
I greatly appreciate the efforts you have gone to on this.
Maybe Karsten's solution then is the best way to go, but only if his cone arrowheads could be made to be scale independent (ie always small).
Another possible work around would be to have 2 perpendicular associated planes with each vector, like shown below, however with only one arrow displayed at any one time. The display would be triggered on/off (or off/on) based on angle of incidence to screen view.
Again thanks you so much for looking to solve this
PS the work you have done to date for display "flat to screen" will find utility with the "Numbering" node
9363.59 In reply to 9363.57
Something like that would really need some other software rather than MoI. The new dimensions in MoI will be useful for simple cases and light duty but not really for making detailed production drawings like that example.
Various other CAD software have a much more extensive drawing toolset to help make that type of output.
Can we move, orient (align) , size the "Blah" text ? (after draw the arrow lines)
Does the "Blah" text has some of these 3 functions as "native" ones when you draw the arrow lines?
and something like "out" (begin, end) "cut" (when inside) arrow lines?
EDITED: 28 May 2019 by PILOU
9363.61 In reply to 9363.60
MOI + Make2D4Views script ( http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1 ) exported in DXF + free SOLID EDGE 2D DRAFTING ( https://www.plm.automation.siemens.com/plmapp/education/solid-edge/en_us/free-software/free-2d-cad ) = perfect results for technical drawing.
Only thing it has to be done is alignment of views according to appropriate standard - US vs EU ( http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.19 )
Ciao
Mik
9363.62 In reply to 9363.61
even simpler....
MOI + ONSHAPE (free)
Import my MoI .3dm file in Onshape and apply Menu > Create drawing of 3dm
9363.63 In reply to 9363.60
I'll probably try to have an option for moving it but align or sizing is not likely.
Sorry I don't understand this part.
I'm going to be working on having text cut the arrow line, the text part is still not finished yet.
9363.64 In reply to 9363.58
Hi James,
I gave this a try, here's what it looks like:
Doesn't seem too satisfying in removing planar feel to it, if you pause the video at various spots things still seem pretty planar.
9363.65 In reply to 9363.64
Michael,
On the contrary, I think it is most satisfactory. Vectors after all are just aids for visualising spatial constraint in the construction process; not for final output.
Thank you so much, brilliant work
Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  106-113
