Any parametric updates?
 1  …  62-81  82-101  102-113
9363.102 In reply to 9363.101
Hi Pilou, yes if you do something like scale them the text will update. There will be an option to override that with your own fixed text value if you want though.
9363.103 In reply to 9363.100
Hi Michael ...
Brilliant!
eric
9363.104 In reply to 9363.100
This dimensioning will be tremendously useful.
Right now I'm awkwardly using the current Text entry for labeling geometry.
It seems that current Text entry requires quite a bit of memory.
What sort of memory load will the new dimensioning require?
9363.105 In reply to 9363.104
Hi Brian, the new dimensions use only a tiny amount of memory. Text is stored just as a text string value not as a bunch of curve and surface geometry. It will definitely be a far better method for labels.
9363.106
So much looking forward to using those dimensions.
Great job Michael, please keep up the good work.
Juraj
9363.107 In reply to 9363.100
I think I'll also do an option for a bracket type textbox outline like this:
I really wanted to do a circle too but it will take too much work for now.
9363.108 In reply to 9363.107
9363.109
Nice work Micheal!
Thank you!
9363.110
Hi Michael - a nice addition to the notes - good to give each cad program its own visual identity when creating notes and this one certainly gives that to MoI.
Looking forward to final release on v4.
9363.111 In reply to 9363.108
Hello Michael.
Honestly, a great job with these dimensions!
Congrats.
I don't use it (I don'use Moi for engineering purposes) but I know that many people here are waiting for this feature.
When the next beta will be released with this new feature?
9363.112 In reply to 9363.111
Hi Marco,
As soon as it's finished up! The remaining work is to set up UI for modifying the various properties, setting up commands for creating them, and seeing if I can get them exporting to DXF/PDF formats.
Hopefully none of these will take too long but it's pretty hard to know in advance exactly how long it will take.
9363.113 In reply to 9363.112
Ok Michael.
Got it.
Show messages:  1  …  42-61  62-81  82-101  102-113
