3D Print hole patch
All  1  2-6
9362.2 In reply to 9362.1
select inside wall of hole and hit delete.
select edge of inside surface hole and hit delete.
select edge of outside surface hole and delete.
no more hole.
EDITED: 9 May 2019 by BURRMAN
Size: 35.2 KB, Downloaded: 25 times, Dimensions: 695x686px
Size: 64.3 KB, Downloaded: 17 times, Dimensions: 1025x1009px
Size: 61.4 KB, Downloaded: 17 times, Dimensions: 966x1025px
9362.3 In reply to 9362.2
(bangs head in desk again) :) geez
Thank you , so simple
9362.4 In reply to 9362.3
Well DigiD,
It is only "so simple" under certain circumstances.. that hole is oit there all by itself. If the hole was involved in an area like a boolean or fillet, it would get more compex.
Essentially, the area where we just push delete, is "untim-able" unto itself.
Try to grab what that means, then the complex one will be understandable.....
9362.5 In reply to 9362.3
@DigiD, by the way there is an object repair tutorial here which goes into some more detail about what is involved in a more complicated situation when the hole is not so self contained and runs into other nearby stuff:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
9362.6 In reply to 9362.5
thanks for the link Michael , I will probably be using those tricks sooner than later
Laughed when I read ( the "whole" hole ) for some reason it reminded me of the Bugs Bunny or Wile E cartoon episode that used "ACME portable holes" a very useful product. I need to order ACME portable patches :)
Show messages: All  1  2-6
