How can I close this?
All  1-4  5-10
9361.5 In reply to 9361.4
Sorry, I just saw this, as I appear to have failed to subscribe to my own post.
I have attached the component that I was unable to close properly. I have since rebuilt the part, but it would definitely be nice to know what I was doing wrong.
Thank you for your help.
9361.6 In reply to 9361.5
Just make sure you selected ALL parts of your curve (some are small in the fillets) and use blend to do the close, works like a charm...
Size: 144.5 KB, Downloaded: 52 times, Dimensions: 745x572px
9361.7 In reply to 9361.5
Hi Lee, thanks for posting the file. So in your model one side of the hole area does not appear to be entirely planar. So I think that's why an extrusion from one side to the other is not joining in well.
If you use something like a Loft between the 2 sides that should join in ok in this case.
It's also possible to fill in holes like this by removing trimming boundaries, there is some information on doing an "untrim" here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
And there is a tutorial on this kind of process here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
9361.8 In reply to 9361.6
Thanks Death. Right on. The test now would be if you could boolean subtract from it now. No matter how I close it, when I try the boolean difference the result is an open mesh.
9361.9 In reply to 9361.7
Thank you Michael - Makes sense. I'm still getting the hang of this, so my models are a bit sloppy.
I will visit the two links you provided. I appreciate the help.
9361.10 In reply to 9361.8
Ok, I think your problem is that you do NOT have a solid when you do the subtract.
I used the surface and then blended the bottom edges (2 opposite edges, 0 Bulge),
then I did the same with the front and back openings.
Now Union the the thing and you get a solid from the which you can Boolean whatever you want...
Show messages: All  1-4  5-10
