Snap on Surface in 3D and Ortho
All  1-7  8-9
9360.8 In reply to 9360.7
Hi Tom the "Snap Radius" is how close the mouse pointer needs to be on the screen to a snap point for it to engage.
So if you put for example 50 in there you would need to have your mouse 50 pixels away from a snap point for it to use that snap.
If you want snaps to engage more easily then you can put a larger value in there and if you want them to only engage when you are quite close to them you would put in a smaller value.
> - I would like MOI to display the points in smaller size ? How to ?
The point display is one of the few remaining areas that is drawn from a bitmap instead of procedurally. So there isn't any setting to modify for this but if you modify the bitmap images to make the images smaller that would work.
There are 4 images that you'd need to modify, they are all in the UI subfolder:
- Is there a shortcut to open the window "3d view angles" directlly ?
Yup, you can use this:
script: /* Show 3D view angles dialog */ moi.ui.createDialog( 'moi://ui/ViewAngleDialog.htm' );
9360.9 In reply to 9360.8
Thank you again for your fanatsticg support, Michael !
TOM
Show messages: All  1-7  8-9
