Snap on Surface in 3D and Ortho
All  1-4  5-9
9360.5 In reply to 9360.4
Hi Michael, grid and straight turned off.
[*] Git it ! > I had missed to restart the file, now ot works.
Btw, where do I find I descriptio regarding the Grid-settings in
the Options-menu ?
EDITED: 8 May 2019 by SIRTOM
9360.6 In reply to 9360.5
Hi Tom, I'm glad you got it working now!
> the Options-menu ?
There is no separate description available for these since it's pretty self descriptive.
"Show grid" shows or hides the grid.
"Show grid axes" shows the grid x/y axes.
"Grid size" sets the distance between grid lines.
"Snap size" sets the distance to use for grid snapping, it can be set separately from the grid size like you have grid size = 1 and snap size = 0.5 which will then make it snap at 0.5, 1.0, 1.5, 2.0, etc...
"Accented lines every" controls the frequency of accented grid lines. So for example Accented lines every 5 means every 5th line is an accented one.
X axis color controls the color of the view's horizontal grid line.
Y axis color controls the color of the view's vertical grid line.
"Grid Lines" and "Accented grid lines" controls the line width, color and line style of either the regular grid lines or the accented grid lines.
Is there a particular setting that you need to know more about?
9360.7 In reply to 9360.6
Thank you for the infos !
I tried different setting for "Snap Radius" in the Options Menu
but did not notice any difference in the snapping behaviour.
So what exactly does this setting apply to ?
And here 2 questions regarding another topic :
- I would like MOI to display the points in smaller size ? How to ?
- Is there a shortcut to open the window "3d view angles" directlly ?
9360.8 In reply to 9360.7
Hi Tom the "Snap Radius" is how close the mouse pointer needs to be on the screen to a snap point for it to engage.
So if you put for example 50 in there you would need to have your mouse 50 pixels away from a snap point for it to use that snap.
If you want snaps to engage more easily then you can put a larger value in there and if you want them to only engage when you are quite close to them you would put in a smaller value.
The point display is one of the few remaining areas that is drawn from a bitmap instead of procedurally. So there isn't any setting to modify for this but if you modify the bitmap images to make the images smaller that would work.
There are 4 images that you'd need to modify, they are all in the UI subfolder:
Yup, you can use this:
script: /* Show 3D view angles dialog */ moi.ui.createDialog( 'moi://ui/ViewAngleDialog.htm' );
9360.9 In reply to 9360.8
Thank you again for your fanatsticg support, Michael !
TOM
Show messages: All  1-4  5-9
