Different polygon names in Poser
All  1-2  3-7
936.3 In reply to 936.1
I think I may be able to write a utility program for you that will break the OBJ apart into separate pieces like you want though, give me just a bit here...
936.4 In reply to 936.1
Hi Pozero - I have written a utility program for you that may help.
You can download it here: http://moi3d.com/download/SeparateOBJ.zip
When you unzip it, there will be a SeparateOBJ.exe program, which you can run. It will ask you for the name of an .obj file, and after you give it one it will edit the OBJ file to break larger objects up into smaller object pieces.
Please let me know if the edited OBJ file works better for you or not.
936.5 In reply to 936.4
Michael thanks a lot on everything you done here for me. I learned how to export OBJ's with separated polygons but my reall problems is in Poser Setup and Material room. I'll search informations on Poser Forum. MoI is the best there is.
Respect Michael
936.6 In reply to 936.5
Hi Pozero - did the utility program not help anything?
I was thinking that after running the utility program on an OBJ file saved from MoI, you should end up seeing different pieces for the Robot object.
They wouldn't be named anything as useful as "left arm", etc, but they should show up as "object1", "object2", "object3", etc..., instead of showing up all as one single object.
Maybe I didn't understand your original question properly?
But yes, I don't really know how the Poser setup and material room works myself, to get details on that you'll definitely need to go to the Poser forum.
936.7 In reply to 936.6
Michael we think of the same thing. I want to have object1, 2, 3....like a different parts of sam prop. I use your utility and it's working. I separate polygons with it. Thanks a lot Michael. Utility really helps. MoI is the best modeling software ever but I have problems inside Poser and that's where problems beggins so...it;s my fault...I have to learn of Poser Setup and Material room.
EDITED: 20 Sep 2007 by POZERO
Show messages: All  1-2  3-7
