Getting camera view and restore it
All  1-9  10-12
9356.10 In reply to 9356.9
I always get the commas as the decimal separator. This is the return of the last script:
Camera=10,24 -20,48 10,24
Target=0 0 0
My system is set to German.
Samba
9356.11 In reply to 9356.10
Hi Samba, and that doesn't work to put in those comma decimal separator values in the dialog?
Here's another version that should make period decimal separators:
script: function str(pt) { return moi.ui.formatCoordinate(pt.x,2).replace(',', '.') + ' ' + moi.ui.formatCoordinate(pt.y,2).replace(',', '.') + ' ' + moi.ui.formatCoordinate(pt.z,2).replace(',', '.'); } var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); moi.copyTextToClipboard( 'Camera=' + str(v.cameraPt) + '\r\nTarget=' + str(v.targetPt) );
9356.12 In reply to 9356.11
it's a bit funny. The extended view angle dialog shows the camera and target position with commas on my system, but it only accepts the coordinates with a period decimal separator.
So, the last script solved the problem for me.
Thank you very much for spending so much time.
Samba
Show messages: All  1-9  10-12
