Fillet Problem Due to Seam ?
All  1-3  4-6
9355.4 In reply to 9355.1
Hi flippyfloop attached here is another version with the seam rotated like Burr's.
My method is Edit > Separate on the sphere face. Do an "untrim" by selecting one edge of it, then Ctrl+A for select all then Delete. Then Transform > Rotate > Rotate axis to rotate the sphere, then Edit > Trim and use the "Select naked edges" shortcut key (http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2) in the step where you are selecting cutting objects. Then Edit > Join to glue it back together.
9355.5 In reply to 9355.4
That works great thanks.
Was not aware of the Untrim function & the Naked Edges. Both very helpful.
Cheers.
9355.6 In reply to 9355.4
Thanks Michael,
I reread my post, which was utterly unclear and insufficient..........
Show messages: All  1-3  4-6
