SMOOTHER
All  1-4  5-13
9349.5
I came to the same conclusion as Michael without cutting the Geo you will end up with a lumpy triangle at the hole.
One solution is to extend the parallel lines and cut that section and rebuild.
I have done a video of the process here: https://youtu.be/8V6pNRy0Plw
Added a new version with narration: https://youtu.be/kX_ozWvGbB4
Also attached the *fixed* file for you to compare. They won't be exactly the same but they are visually close and you won't have a triangle artefact.
EDITED: 28 Apr 2019 by MARKBTOMLINSON
Mine :)
9349.7
Fine. Smoother than mine! Thank you.
Pilou - how did you solve it?
MaLa
9349.8 In reply to 9349.7
I don't know if i had solved it! But sufficient for me for funny rendering! :)
- Blend the bottom longitudinal arcs for have an arc for close the form
- Nside
- Kill all little parts except the "Ray Manta" and big vertical part
- Copy the longitudinal arcs who are on the same vertical plan
- Blend them
- Extrude both side (the "box" was a try)
- Trim the "Ray Manta"
- Blend the 2 Lateral Arcs
et voilĂ  :)
EDITED: 28 Apr 2019 by PILOU
9349.9 In reply to 9349.8
oh...too complex for my skills...in MOI and English...
9349.10 In reply to 9349.9
Did you see the video I posted it is very straightforward to do.
3D Hard Surface
https://mbt3d.com
https://www.artstation.com/artist/markbtomlinson
9349.11
Another one:
Blend - Tangent curves -Projected - 2Rail Sweep with two profiles.
EDITED: 30 Apr 2019 by KMRQUS
Size: 422.2 KB, Downloaded: 45 times, Dimensions: 696x718px
9349.12 In reply to 9349.10
Hi Mark,
yes, I saw it. Found it very smart.
What I noticed now is your info to blend. Pretty nice. Thank you very much...!
Best, Mala
9349.13 In reply to 9349.12
Glad it helped all the best!
3D Hard Surface
https://mbt3d.com
Show messages: All  1-4  5-13
