SMOOTHER
All  1  2-13
9349.2 In reply to 9349.1
Hi Lara, so for the upper piece you can select these 2 edges and use Construct > Blend:
For the remaining hole, unfortunately filling in that kind of smooth hole filling is difficult to do in MoI, you will probably need to use some tools that are in Rhino to help with that. I'd probably give the Patch command in Rhino a try for that, maybe after cutting away a little more surrounding area.
9349.3 In reply to 9349.2
After doing the Blend like Michael said, I tested to take th three edges and an n-sided finished the job.
Is it ok or I made a error ?
I tested to do a shell next to verify the surface and I had a solid. So it's seems to be good. No ?
9349.4 In reply to 9349.3
Hi Phiro, that does work to fill the hole but it doesn't make a very pleasing shape. You can see some evidence of the triangular outline in the shaping if you inspect it closely.
9349.5
I came to the same conclusion as Michael without cutting the Geo you will end up with a lumpy triangle at the hole.
One solution is to extend the parallel lines and cut that section and rebuild.
I have done a video of the process here: https://youtu.be/8V6pNRy0Plw
Added a new version with narration: https://youtu.be/kX_ozWvGbB4
Also attached the *fixed* file for you to compare. They won't be exactly the same but they are visually close and you won't have a triangle artefact.
EDITED: 28 Apr 2019 by MARKBTOMLINSON
Mine :)
9349.7
Fine. Smoother than mine! Thank you.
Pilou - how did you solve it?
MaLa
9349.8 In reply to 9349.7
I don't know if i had solved it! But sufficient for me for funny rendering! :)
- Blend the bottom longitudinal arcs for have an arc for close the form
- Nside
- Kill all little parts except the "Ray Manta" and big vertical part
- Copy the longitudinal arcs who are on the same vertical plan
- Blend them
- Extrude both side (the "box" was a try)
- Trim the "Ray Manta"
- Blend the 2 Lateral Arcs
et voilĂ  :)
EDITED: 28 Apr 2019 by PILOU
9349.9 In reply to 9349.8
oh...too complex for my skills...in MOI and English...
9349.10 In reply to 9349.9
Did you see the video I posted it is very straightforward to do.
3D Hard Surface
https://mbt3d.com
https://www.artstation.com/artist/markbtomlinson
9349.11
Another one:
Blend - Tangent curves -Projected - 2Rail Sweep with two profiles.
EDITED: 30 Apr 2019 by KMRQUS
Size: 422.2 KB, Downloaded: 45 times, Dimensions: 696x718px
9349.12 In reply to 9349.10
Hi Mark,
yes, I saw it. Found it very smart.
What I noticed now is your info to blend. Pretty nice. Thank you very much...!
Best, Mala
9349.13 In reply to 9349.12
Glad it helped all the best!
3D Hard Surface
https://mbt3d.com
Show messages: All  1  2-13
