import OBJ is not keeping geom in correct location
All  1-3  4-7
9343.4 In reply to 9343.3
Hi Jason,
> P.S. I have the "impObj exact" now working as a short cut but I'm not able to find the same command
> that's being issued using max's impObj menu button. Is it using impSubDiv perhaps?
I don't think so... What version of CustomUI and MoI are you using?
9343.5 In reply to 9343.4
I believe latest version but it's a bit of a blurr as I've added dark gui etc. on top. But this command should reside either in native program files or %appdata%
C:\Program Files\MoI 4.0 beta Feb-27-2019\..
I find the following using search of *imp*
Import.js
ImportPart.js
ImportSubD.js
%appdata%\Roaming\Moi\..
_ImportObj.js (which is v.1.5)
9343.6 In reply to 9343.5
Hi Jason, maybe it's easiest to modify the _ImportObj.js file to always do "exact" mode and then it wouldn't matter how you were launching it.
To do that, edit the file _ImportObj.js in a text editor, then on line 10 there is currently this:
if ( moi.command.getCommandLineParams() ==='exact' ) { moi.ui.commandUI.normalizeObj( false ) } else { moi.ui.commandUI.normalizeObj( true ) }
Delete that or comment it out by putting in a // at the front of it, and then have this instead:
moi.ui.commandUI.normalizeObj( false );
9343.7 In reply to 9343.6
Thanks a bunch for that code Michael. Works and doesn't throw an error leaving "_ImportObj exact" as a command input either for hotkey.
Show messages: All  1-3  4-7
