Curve projection question
All  1  2-7
9335.2 In reply to 9335.1
Hi Elliot, when you extrude a curve you'll only get a solid result with capped ends if your curve is closed and planar.
But if you extrude a surface you'll be able to get end caps in the situation you're describing. So the usual method would be to trim the surface with your curve as a cutting object, and Trim actually has projection built into it so you don't need to project as a separate step. Then when you have your surface fragment you can extrude that into a solid.
Check out here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3024.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=4010.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=3318.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
Hope that helps! - Michael
9335.3 In reply to 9335.1
With any image & file that is difficult to answer..
If you want "project" a solid to a surface use the Flow Function!
9335.4 In reply to 9335.2
Many Thanks Michael,
Problem solved!
9335.5 In reply to 9335.3
Salut Pilou,
The flow function looks great, and would definitely come in handy - but I cannot find it on the MOI interface.
Sorry, still new.
Thanks.
9335.6 In reply to 9335.5
Transform / Deform / Flow! ;)
EDITED: 11 Apr 2019 by PILOU
9335.7 In reply to 9335.6
Thank you!
Show messages: All  1  2-7
