Script request
1-10
11-30
31-35
nameless
3 Mar 2020 (31 of 35)
9322.31
In reply to
9322.30
Hi Quaritexa,
Did you end up modifying the second script? Can you share the script version that works 100% for you?
I will play with the line Michael pointed at and see what I get just for fun.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
vector illustrator (QUARITEXA)
4 Mar 2020 (32 of 35)
9322.32
In reply to
9322.31
yes
SetNearestOrthoView.js
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
nameless
5 Mar 2020 (33 of 35)
9322.33
In reply to
9322.32
Thanks! I tested it and I got an odd single instance of weird rotation, but I couldn't reproduce it and it seems to be working fine in all angles now. super!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
29 Jun 2020 (34 of 35)
9322.34
Seems not for me... Must be the big full top face view no ? Not sure...
What is the nearest ?
EDITED: 29 Jun 2020 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
29 Jun 2020 (35 of 35)
9322.35
Else in case of...you can input any numbers
script: /* Toggle FOV */ var other_angle = 40.0; var v = moi.ui.mainWindow.viewpanel.getViewport('3d'); if ( v.projection == 'Perspective' ) { if ( v.fieldOfViewAngle == other_angle ) { v.fieldOfViewAngle = 27.5; } else { v.fieldOfViewAngle = other_angle; } }
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
11-30
31-35
