Script request
 1-9  10-29  30-35
9322.10 In reply to 9322.9
This is a very interesting function. It reminds me of a blender viewport behaviour I quite enjoy. What quaritexa suggests brings it even closer.
Is it possible to assign a mouseclick in shortcuts field? (Like Alt+ Middle Mouse Button or something)
9322.11 In reply to 9322.10
I don't know about v4, but on v3 you can assign it with external utility: autohotkey.com (windows), hammerspoon.org (mac).
With ahk v2 it is:
#if WinActive("ahk_class MoiMainWindow ahk_exe MoI.exe")
and not WinActive("ahk_class #32770")
!MButton:: Send "5" ;SetNearestOrthoView.js
And bind 'SetNearestOrthoView.js' to '5' in moi's shortcut keys.
EDITED: 25 Feb 2020 by QUARITEXA
9322.12 In reply to 9322.9
Hi Quaritexa,
> It's not a file. The problem is the correct orientation of the ortho view. Look...
Having the file of what you show in the screenshot just would have helped me repeat your steps.
But it's clearer to me now with your last one.
I guess it might be possible to do that by applying a tilt to the Top view but that will have some side effects because it will stay tilted until you manually reset it to have a 0 tilt angle. So I'm not sure that would work very well.
I think the process to modify the script to do that would be something like: after the ortho view is set, get view.cameraFrame from it and form 4 potential directions, one for cameraFrame.xaxis, cameraFrame.yaxis, cameraFrame.xaxis flipped, cameraFrame.yaxis flipped, and find the closest match from those and set view.tiltAngle to either 0, 90, 180, or 270 .
9322.13 In reply to 9322.12
Unfortunately, I don't know moi scripting well enough to implement this small option.
9322.14 In reply to 9322.12
Are there currently any scripts which set the tilt for top view?
I see your code for getting the tilt in the forum topic "Align 3dview to surface".
Wikipedia's ortho view topic is interesting.
-Brian
9322.15 In reply to 9322.14
Some info here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8104.2
9322.16 In reply to 9322.15
Thank you.
- B
9322.17 In reply to 9322.13
Hi Quaritexa,
Well like many things it's quite a bit more complicated than you might think at first.
But I've attached a version that's pretty close, give it a try. I think it's doing what you wanted when it is locking on the the Top or Bottom view but not quite right with Front or Side views.
9322.18 In reply to 9322.17
I want to jump in and say how useful this script is. It makes switching to ortho views so much more natural, at least for me.
I prefer the ambiguity of the top and bottom views of the first script, compared to the side view one of the second version. Thanks QT for bringing this to my attention and Michael for the work on the scripts.
In my opinion this script is so helpful, it should be bundled with MoI in some form. I have developed sufficient muscle memory with F shortucts to toggle each view, but this script beats it by far. Combined with the align C plane to selected it completes the deal. Very impressed :)
9322.19 In reply to 9322.18
This Views switching is very convenient. I've using it for the several days. If it were possible to solve the tilt problem, it would be generally luxurious.
9322.20 In reply to 9322.17
possibly what they want is just throwing the "Camera" in the 3d viewport, to that particular perspective. not really going to the actual "TOP". So that would then keep all the UCS twist and rotation stuff, without resetting it.
Is it possible to get that camera point without moving to the actual ortho viewport? Just a thought.....
9322.21 In reply to 9322.19
Hi Quaritexa,
I posted an updated script that handles Tilt for the Top/Bottom views:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9322.17
It should be behaving like the example images you posted above.
9322.22 In reply to 9322.20
Hi Burr, yes another possibility could be to change the 3D view's camera location only instead of switching to the ortho viewport. But that would involve switching more things around like the construction plane and also probably switching perspective projection on and off.
There is also additional 2D behavior that you get in the ortho views like when drawing snap points will project to a common plane instead of allowing a drawn object to vary in height.
It is possible.
9322.23 In reply to 9322.20
Hi BurrMan,
Actually, the current state is better than what you describe in my opinion, as true ortho views offer different functionality (gizmo, array behavior) than a 3d cam of the same angle. I find the original script awesome. Only top and bottom views can potentially snap to a different angle than what you would expect, which is very minor and you can easily work around it.
9322.24 In reply to 9322.23
Ok, good. I just misread the intent of the request.
9322.25 In reply to 9322.21
I tested both scripts. And in some angles it works wrong:
https://dl.dropboxusercontent.com/s/kxy9marh3cthohz/_SetNearestOrthoView.mp4
9322.26 In reply to 9322.25
Hi Quaritexa, currently what the second script tries to do is to match the x-axis direction of the 3D view's cplane by tilting the ortho view.
If your view is not centered on the cplane origin then it will probably lead to those kinds of problems.
I think that the problem is that the "right thing to do" needs to be more completely and definitely specified. It's not possible to write a script just by writing "Do what I was thinking", it has to be broken down into very specific steps.
If you can describe a more detailed and exact algorithm for how it should work, that would help.
9322.27 In reply to 9322.26
I think it needs to rotate only top and bottom projection accordingly to 3d view.
SetNearestOrthoView2.js do it like expected. It switches this view:
to that:
But after it once switch the top view, it starts wrong switching the side view. From this:
to that:
9322.28 In reply to 9322.26
Michael, have I explained in sufficient detail or do I need to add something else? I apologize in advance if I express myself incomprehensibly. English is not my native language.
9322.29 In reply to 9322.28
Hi Quaritexa, I've been trying what you were describing but I've been getting inconsistent results that have been confusing me. I'm not sure if there is a bug that I haven't been able to track down or something like that.
I don't think that I will be able to experiment with it much more right now, it's very time consuming.
If you want to test just modifying the #2 version to only do the twist on Top or Bottom views, you could try modifying the script by finding the part that has this comment:
// Added below for calculating tilt.
and right below that put in an
if ( name == 'Top' || name == 'Bottom' )
>>Put the tilt processing here
Show messages:  1-9  10-29  30-35
