Shortcut key backup
All  1-2  3-5
9319.3 In reply to 9319.2
Hi Pilou, thank you for the quick answer. Yes, I have found the file from the path you provided. It works now. Thanks a lot.
Justin
9319.4 In reply to 9319.1
Hi Justin, so by default Windows (since Vista) prevents programs from modifying the contents of the "Program Files" directory as a security measure. So that's why MoI does not write its moi.ini settings file there by default and instead puts it in %AppData%\Moi .
9319.5 In reply to 9319.4
Hi Michael, thank you for the reply. The problem is solved. Thanks.
Justin
Show messages: All  1-2  3-5
