How to apply a dimension constraint to a profile used for a sweep?
All  1  2-3
9318.2 In reply to 9318.1
Hi skipper, so do you mean you want to rotate 2 split halves similar to this? :
But won't that introduce a cusp in your profile at the rotation point here? :
Or ok I guess now that I read your question again it sounds like you are going to rotate only half the control points and not a cut apart piece.
So I guess what you would do would be to offset the centerline by half your desired thickness:
Then your end location would be the intersection of a circle with origin at your rotation origin and going through your endpoint, with the offset line:
The rotate command does internally create such a circle automatically and provides an intersection snap point so you can skip making the circle and only make the offset line.
Does that do what you need?
9318.3 In reply to 9318.1
A guy made an airfoil command awhile back. Maybe you could use that and plug in your numbers? Or do you want to hand build it?
Show messages: All  1  2-3
