Wall Panel - Houdini Apprentice -> MoI
 1-18  19-38  39-58  59-75
9316.59 In reply to 9316.58
the PaQ's set-Up is only for Houdini for be sure ?
Yes, only for Houdini.
you can try to do the same with ArtForm and the function "Region Relief",
once you have imported the curves and defined them as new model.
9316.62 In reply to 9316.61
I will try that! :)
I have ArtForm Pro 3.5 (or named 4.0 at start screen)
Does it Updated for a new free version ? (yet sufficient...just for info... :)
(remember that was a little trick to install :)
And it's not an easy intuitive prog! :)
EDITED: 27 Mar 2019 by PILOU
3.5 or 4.0 is imho the same, they renamed it only because of the Pro vers. which
was 3.0 IIRC.
About update, it checks for updates but you have to login and try to get the latest
version. I tried that but could not find it and the thread show me a little lock when
i want to download. Translated it says i must send a message to the admin/moderator
to get the file.
9316.64 In reply to 9316.63
No problem, it was yet a fabulous prog!
Here is another idea from an old MoI file. Not sure if polygon meshes can be used for
vacu forming wall panels …
sac
Peano curve like :)
:-) , it is a Sierpiński curve (arrow head).
O.k. before i go on and do other things, one more. Hope you like.
spiroribbon16
9316.69 In reply to 9316.68
This is wonderful.
Congrats!
Thank you Marco!
Spirographic!
Yes Pilou. :-)
Hi all,
i like to share two more examples. This time round and with more colors.
For those two i used two well known color schemes. Hope you like!
wg
exotic princess names
wgp
9316.74 In reply to 9316.73
lovely as usual
Thank you very much!
Show messages:  1-18  19-38  39-58  59-75
