Wall Panel - Houdini Apprentice -> MoI
 1  2-21  22-41  42-61  62-75
Will be fun if we can have such volumes as you show from any 2 D plan! :)
seems remember normal landscape builder prog can make that ...(not yet tested)
i think it should be possible if you use Kai Krause's good old
ChOps technique, for Photoshop, from the early 90's, or if
you use my technique NURBS shapes from shading.
https://www.behance.net/gallery/67631047/(NURBS)-shapes-from-shading
here is a small example what one can do with Kai's technique in Photoshop.
I created the text "Cool Tools" with the HOBO font, blurred it and then used
Kai's technique. His technique makes so many variations possible that you
can archive very different looks, when using more ChOps (Channel Operations).
ct
9316.25 In reply to 9316.21
Hi Stefan,
Why is there a link to a bank in your post ?
9316.26
Hi Stefan,
So here's a little setup that combine HF and COPS (Heightfield and image compositing).
I tried to add comments here and there.
The sub-d import method is probably overkill, especially if you want to get very dense detail.
I'm pretty sure it's possible to export an .igs nurbs surface directly from Houdini (but not with the apprentice :S). I will have a look at it today.
EDITED: 2 Aug 2023 by PAQ
Hi PaQ,
thanks a lot! Now this is very interesting to generate images from the mesh and then save them. :-)
Houdini is really amazing what one can do with it. Wish i had concentrated more on Houdini and not
on so many other apps …
@Mip Sorry about that, the links are sometimes inserted automatically from the free hosting provider
i use. If someone can tell me a better hosting provider i am all ears. I am currently using postimages.org.
a bit off-topic, but I used your image and re-created it in MoI and then used ArtForm,
which you also have. In ArtForm you can save the model as bitmap and then prepare
the bitmap for ZSurf.
Please note: I did not used any smoothing brushes, only wanted to show you a quick
way with MoI, ArForm and ZSurf.
(With JDPaint one can save this model also as NURBS model … )
pilou3
pilou4b
pilou6
Back on topic … I rendered one more image with a more natural (outside) look
while using a sandstone texture. I think this might be an interesting topic for
ArchViz Designers to create such wall panels with Houdini and MoI. I could
imagine colored, like the first one, for interior design and this one for outside
walls.
panel2
9316.30
<Houdini is really amazing what one can do with it. Wish i had concentrated more on Houdini and not
on so many other apps …>
Yup, it's a 3D sandbox :)
Here's an little example of what you can do with curves too, looks close from your last post.
For every points of the grid, I compute the distance of the closest point from every curves ... then I remap this distance with my own profile, and use the result as displace (elevation).
Displace strength, max distance search and profile options are in the pink node.
EDITED: 25 Sep 2020 by PAQ
WOW, that looks pretty awesome! Thanks a lot for sharing the file!
This Host free easy one (Sections galleries) since more 10 years... : https://postimages.org/fr/ i don't see publicities maybe because of my Navigator ...
else
Very cool results!
By Stefan
Ah yes Artform...forget to explore more in depth ;) http://www.jingdiaosoft.com/products/artform.html#
(made an how to...in French...http://moiscript.weebly.com/artform.html
Houdini : ...alas not for this life even there is a free version Apprentice! :) https://www.sidefx.com/products/compare/
EDITED: 24 Mar 2019 by PILOU
And funny all that was spoken ... ;)
return to the past (2007) http://moi3d.com/forum/index.php?webtag=MOI&msg=602.1
and enlight this cool tuto! ;)
http://www.anim8or.com/tutorials/from_users/focal_blur/focalblur_1.html
@PaQ : cool try of the 2D adaptation from my little image! Bravo!
Else
ZSurf 4 works like a charm!
Just difficult to find the good format bmp! (for me only prog Paint : 24 bits works! :)
Here texture from my old PhotoImpact more than 20 years old!!! :)
Of course another infinite possibilities! :) Render the very cool free SimLab Composer lite! ;) (max 1920 *1080 - Real Time)
9316.35 In reply to 9316.34
cool results pilou
It makes also some text projections on primitive volumes! ;)
9316.37
So yes, if you can afford the indie version, you can simply convert the grid into a Nurbs surface, and export it as .igs.
Here's a 512*512 grid, file size (igs) is about 15Mb, almost instant loading in MoI.
9316.38
Torturing MoI =O) (1024*1024 terrain)
Curious : seems freeCad is very slow to import iges files from ZSurf! 2 minutes ! ( for 3.38 Megas ! )
Moi it's 1 second!
Idem when the same file is saved from Moi in IGES! it was the simple Pilou text surface above!
It's the same for you?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/srf.igs
About terrain
@ PaQ have you tryed GAEA that i am translating the site! ;)
https://gaeafr.weebly.com
9316.41 In reply to 9316.40
Yes I have heard about it !!!. Looks really great, and Dax Pandhi is a really good artist.
Out of the box it's probably a way faster solution than Houdini (especially the texturing, colors looks gorgeous !) ... but I really prefer to trade speed for flexibility these days ;)
Show messages:  1  2-21  22-41  42-61  62-75
