Problems converting Solidworks files to OBJ using MOI (misaligned edges and missing polygons)
All  1-5  6-8
9312.6 In reply to 9312.4
That's really helpful! I realized that both of the places in your screenshots are places I used the same tool to fix the geometry. What happened is that I used the delete and patch tool in Solidworks to merge all of the corners in those locations. That's apparently what the real geometry looked like before I did that. Solidworks showed it the way I wanted it to look and so did those other programs but apparently that geometry was still there and only MOI, Rhino, and ViaCAD could see it. I got rid of that operation and now it exports without issue! I still need to clean up those corners but it'll be easier to do that in Houdini after its been converted to OBJ. Thank you!
9312.7 In reply to 9312.5
That is going to be so helpful going forward. Thank you!
Houdini has Nurbs ?
Show messages: All  1-5  6-8
