Some documentation available now
 1-4  5-24  25-44  45-48
931.45 In reply to 931.44
:) Now no possible confusion :)
In the command Transform / Array /Circular we can read
"This can be used to create sprial type patterns"
I suppose that is spiral :)
931.47 In reply to 931.46
Thanks Pilou, yup that was supposed to be spiral - fixed now!
About the Helpers lines seems you must add a little line before the use of the little marker :)
for say that you can use the Numeric Calculator for Distance and Angle box
This distance will block the helpers lines next point along it, and angles will makes steps rotations around the first point clicked+drag with angle input it.
Some powerlful indeed!
EDITED: 30 Sep 2007 by PILOU
Show messages:  1-4  5-24  25-44  45-48
