Objects unpaintable in Substance Painter
 1-16  17-26
9309.17 In reply to 9309.16
if you want really fast quick-and-dirty UVs without much distortion, just in order to be able to use Substance Painter, I would recommend using MODO's atlas projection feature.
That's just one click for each object, then you pack the uvs and you are done.
IMHO this UV mapping is far from perfect (it wastes space), but it might be good enough - the distortion is minimized
I do this all the time in order to get stuff into Substance Painter quickly.
Here you see 4 different sub objects (from a tutorial for MOI that I am working through right now)
Now I do the atlas projection, just one click (while all objects are selected) and we get UVs for everything, but they are overlapping
Now this is the pack dialog
And this is your UV map.
If you up the rez for your textures you might get acceptable results.
Of course you can create multiple UV maps with this method, for each group of objects that you want to handle in Substance Painter individually.
I do not know if Blender or any other OSS has a comparable feature.
PS Sorry I wanted to reply to the main thread, not the last answer
EDITED: 21 Mar 2019 by HAPPYWEASEL
9309.18 In reply to 9309.16
yeah I guess I overlooked the door and windows rectangle "constructors". The whole wall and door and windows were Boolean "union'd" and named. I must have forgotten to delete the other objects.
Thanks!
EDITED: 21 Mar 2019 by DEATH
9309.19 In reply to 9309.17
Hi HappyWeasel.
Very cool!
But I can't afford Modo, way out of my price-league...
Anyway, pretty cool, it looks like it does what the Virtual Reality Rizom Unfold program does, only it's built into Modo, quite nice!
I tried the RizomUV program and it is very nice and easy to use. But I am trying to avoid the UV unwrapping completely.
It seems that so far the Owlet and Simlab are the candidates for that, they need no further mods of the MoI object to add materials to it.
Thanks for your very nice detailed info, I appreciate the time you guys waste on helping me out.
I am getting closer to the workflow solution I am seeking with every advice I get.
Thanks!
9309.20 In reply to 9309.19
I think there's also a function in Blender, something like "Average UV islands" that could probably process the MoI-generated UV coordinates to make them work better for Substance Painter.
9309.21
Sometimes i use an other fast workflow. MoI + Photoshop
- MoI > Export the model (OBJ)
- Photoshop :
1 - Open the OBJ file
2 - Menu 3D > Generate UV
3 - Menu 3D > Export Layer 3D (choose WavefrontOBJ)
Regards.
JP
9309.22
9309.23 In reply to 9309.21
Hi Finema,
Sounded cool, I tried it, but it acts the same way. Too bad, that would have been really cool and easy.
Anyway, I think I am giving up on unwrapping and re-normalizing/UVing.
Since Owlet works without a problem, the issue is solved, I guess...
EDITED: 22 Mar 2019 by DEATH
9309.24 In reply to 9309.22
Hi submono
The issue is that one actually has to do all that, instead of having it exported with UV mapping working. The unwrapping is a major pain for complex objects and takes way too much time.
But: Owlet and Simlab have no issues with the unmodified object export, I decided to save myself the headache and just use them.
Thanks for the tip though, much appreciated.
9309.25 In reply to 9309.24
Hi Jack (it's Jack, right?),
in the end it all depends on what you want to do with your models. Every asset in any 3D game that you might have played has been meticulously modeled, probably retopoed, unwrapped, mapped, and painted (lately now using PBR workflows). So if you want to see your asset in a game engine, animate it, or if you are part of a production pipeline, unwrapping is just part of the deal. And professionals will always prefer manually unwrapping to the automatic solutions many tools offer because otherwise you lose control which will! haunt you sooner or later.
On the other hand if all you're after are pretty pictures (and sometimes that is all it takes) you can get away with an application like Owlet. These tools provide you with procedural textures and/or will automatically apply a simple uv box mapping for you, maybe even tri-planar, which will work in a lot of cases. But again you give up control for convenience. And you won't be able to export your materials as PBR maps to use them in other applications like Marmoset Toolbag, Unity, etc.
Anyway, I'd say go for Owlet now and see how far it carries you. You can always step up your game later if you feel its limits.
Regards,
Sven
Edit: I've been playing around with the Substance Alchemist beta and the results that one can achieve are impressive (forgotten temple, melting snow). So there are rewards for choosing the "other" way ;)
EDITED: 23 Mar 2019 by SUBMONO
Size: 939.5 KB, Downloaded: 65 times, Dimensions: 1585x894px
Size: 2.1 MB, Downloaded: 73 times, Dimensions: 1990x1862px
9309.26 In reply to 9309.25
Yup, Alchemist is what got me thinking...
It is really cool. And yes, it is Jack...
I agree with your judgement, thanks for the info.
Show messages:  1-16  17-26
