Boolean Diff
All  1  2-6
9306.2 In reply to 9306.1
Your objects are "tangent" just increase Scale 1D and that will works! ;)
EDITED: 17 Mar 2019 by PILOU
9306.3 In reply to 9306.2
Thanks so much Pilou!
Just tried Larger and smaller and works!
Size: 79 KB, Downloaded: 34 times, Dimensions: 1024x766px
9306.4 In reply to 9306.1
Hi JoeZ, it sounds like you've got it figured out, but yes it can be difficult for booleans to handle cases where 2 surfaces are just barely skimming each other with overlapping surface areas. That's a more difficult case for surface/surface intersection to handle.
So it is good to push objects through each other with a little clearance if possible.
9306.5 In reply to 9306.4
Thank you Michael!
And thanks for this forum!
I appreciate all the support!
I've learned so much, reading the post in it, almost daily!
9306.6 In reply to 9306.5
Same for me Jose, this forum is a goldmine :)
Show messages: All  1  2-6
