Behavior of Isolate script
All  1-2  3-6
9300.3 In reply to 9300.2
Wow... Thank you Michael!
Do I lose something vs the other script? I mean, I just replace my usual isolate shortcut with this, right?
<3
9300.4 In reply to 9300.3
Hi nameless, yes you would just replace it with this one. It behaves a little different from your other script though because of the "memory" function where it operates in pairs, one time doing the isolate and taking the snapshot of current state and then when you run it again if there is a previous snapshot it restores that and clears the snapshot.
9300.5 In reply to 9300.4
I really like how it behaves! Thank you Michael, I really really appreciate it.
9300.6 In reply to 9300.5
Hi nameless, no problem I'm glad you like it! When you're using it every once in a while you may forget that you have a memory snapshot saved and instead intended to isolate some other new object. When that happens you just need to trigger it a second time.
Show messages: All  1-2  3-6
