Patch Modelling (Curved Surfaces) Help Required
All  1-3  4-12
9294.4 In reply to 9294.3
Thanks guys, with your help I figured it out. I'm actually just testing some things out. Its not a final model. I have another quick one though. I'm trying to 'cap' a curved surface that was lofted out from my model. but obviously planar wont work..but then neither does blend or network. Any tips here?
I really want to learn this style because I have to do quite a few 'semi-organic' models (camera bodies, car bodies etc) and solid modelling isn't allowing me to get the nice curves I need :) (I try to combine techniques though of course)
I have attached the MOI model file this time too.
Much appreciated!!
9294.5 In reply to 9294.4
Depending of what do you want ?
A plan top? Horizontal, inclined ? A double curvated surface ? etc...
The more easy : draw first your curvated Surface
Draw 2 curves perpendicular, different or not ( arc circle, free form etc..) or take any surface you want : Make a simple Sweep
Then extrude from the ground object your base flower curve
Boolean Merge the sweeped curve and the extruded surface, Keep that interesting you, Boolean Union Cap and lateral surfaces, Fillet
that's All :) 10 second in a rusted state! :)
Of course your start surface can be any complex you want or even a simple plane!
Close directly your proposed curve is some difficult!
In some case Rail Revolve, Nsided can do the job but alas not here (too circonvolutionated)
EDITED: 13 Mar 2019 by PILOU
9294.6 In reply to 9294.5
Whooa! I have no idea how you did that. It was amazing !!
Could you describe step by step? Many Thanks!
9294.7 In reply to 9294.6
Return previous post! ;)
I believe that existing new step to step is sufficient!
For this one i take the general perimeter : Join
Make same previous post
Take a plane as surface
Extrude Perimeter
Boolean Merge
Join wanted surfaces = a simple solid (take a look at the up right Moi screen)
Export as obj only triangles
Alway test Free Owlet 1024*1024 max
9294.8 In reply to 9294.7
Ok thanks. I still don't really understand it but thanks anyway.
9294.9 In reply to 9294.8
Where are you blocked ?
I return in 4 hours!
Some closeup...
Draw the perpendicular curve through edges & first curve a little more bigger
Sweep them
Kill the lateral face
Extrude bottom perimeter
Select surface sweeped Boolean merge with extruded lateral faces
erase that you don't want
join top surface and lateral faces
Fillet (0,2 here)
That's all!
9294.11 In reply to 9294.4
Hi Simon, it's best to form the cap by an intersection with another surface which is what Pilou is showing above.
Even if you are modeling things "patch by patch" there are still many situations where you want to make extended surfaces that then get trimmed with each other rather than trying to literally build every single surface all by itself from non-planar curves.
So for your case here you would want to start with these 2 planar profile curves:
Extrude this one to make an extended base shape that punches through your main body and also extends past the other profile as viewed from the top:
Do boolean difference on the extrusion to cut off the end and leave the imprint of the profile:
Then you trim that and the main body with each other.
If you want to have a more complex curvy "cap" that does not have a single 2D profile curve you would build an extended cutting surface using something like sweep or loft and use that surface as the cutting object in the boolean difference. See here for some a recent examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9281.7
http://moi3d.com/forum/index.php?webtag=MOI&msg=9264.2
Making extended surfaces with simple regular structures that then get trimmed is still a major part of NURBS modeling technique even if you're doing things at a surface level.
With these 2 versions you have seen quasi all Boolan functions! :)
Show messages: All  1-3  4-12
