Curious ?
All  1  2-3
9290.2 In reply to 9290.1
Hi Pilou, you should use Draw curve > Freeform > "Control points" (not "Through points") if you want to have the curve with control points exactly as you input them.
When you use "Through points", that uses a construction method to calculate a curve that will pass through those points but the control points of that curve will be calculated and won't be the same as the input points including if they happen to all be in a straight line. That's just how an interpolated curve works.
9290.3 In reply to 9290.2
That 's more clear! :)
Show messages: All  1  2-3
