Placed Image is a black rectangle
All  1-2  3-4
929.3 In reply to 929.1
Hi Aaron, I wouldn't be surprised if your 3MB image is a highly compressed TIFF image that is actually quite high resolution (like maybe something like 7000x4000 pixels).
The TIFF format is able to compress black and white images with large areas of white in them really well, so that 3MB of highly compressed data becomes a much much larger data size when fully uncompressed to raw texture data.
You'll need to reduce the pixel resolution down to something smaller like 1280x1024 and then it should work.
Rhino works because it is automatically resizing the image to be smaller before trying to send it to the video card. MoI is ending up using a larger sized image which won't fit in your video card's memory.
I should be able to tune this up a bit so that MoI will automatically resize images to a bit smaller in size, right now it only does it to the theoretical maximum size that the card says it supports, but this may still not fit in the actual available memory of the card.
There was also another recent thread on this same issue, see here for more info:
http://moi3d.com/forum/index.php?webtag=MOI&msg=919.1
But to make a long story short, resize the image down to a smaller size and you'll be in business.
929.4 In reply to 929.1
Oops, one other thing:
> I opened up the working rhino file in MOI and again I got nothing, just a plane.
That's actually normal for right now - MoI does not currently read the texture mapping information from Rhino objects.
You probably used the "PictureFrame" command in Rhino? That basically creates a plane object and assigns a texture map to it.
Since MoI doesn't read the texture map information, you will just see the original plane object when you import it into MoI.
Show messages: All  1-2  3-4
