Blender add-ons
 1-19  20-39  40-59  60-79  80-95
Not an addon
9287.42
BATCH OPERATIONS™ 2 is Blender 2.8 add-on and highly sophisticated data/scene manager/outliner.
The primary purpose of this addon is to cut down micromanagement of modifiers, materials, collections and other data. Apply multiple operations (add, remove, assign, etc.) on all objects via 3D view Tab panel / Floating menu / Pie-menu or Context menu. Select / outline / arrange / rename your data via file / scene / layer / visibility / text input filters on the fly and in real-time.
Ideally suited for complex models, scenes, files, whenever you need to clean, reorganize and maintain your project
This is copy paste from the website but in addition also has advanced renaming, ability to switch cameras in real-time and tons of other features.
Be sure to check the full documentation here http://batchops.moth3r.com/
Not sure that following is the more easy! I prefere the free TwinMotion for a more friendly use of Quixel! :)
From a famous Moi user! ;)
Speedflow Companion and the new Cutter function released for the 2.81 ;)
Always Not Destructive or Destructive as you want...
https://twitter.com/pitiwazou/status/1197919688019320832?s=20
Funny thing the trimed object becomes "auto trimer"! :)
Always speddy astonishing!
With the new Blender 2.82 who has
EDITED: 8 Jan 2020 by PILOU
9287.49 In reply to 9287.48
Wonderful things!
next soon ;)
Started! :)
Not addon but Bevel exploration! ;)
9287.55 In reply to 9287.54
Wonderful :)
Thanks!
free https://luxcorerender.org (video in French but they are Subtitle)
François Grassard is also a French Blender Guru ;)
SketchUp on steroïds! :)
9287.58 In reply to 9287.40
That looks so great! It is very similar to what I am trying to achieve with the node editor random building generator that James has so kindly put together. There are some great examples here. I'm fascinated by the amount of traction Blender is starting to generate. It seems like it's becoming quite a serious contender for some of the bigger software companies, even with their software being "industry standard". I definitely need to learn a bit more Blender, but I just love the smooth simplicity of MoI. It's such a pleasure to work with.
9287.59 In reply to 9287.1
I'm surprised no one mentioned these
Makes working with bezier curves a lot easier
Bezier Tools
https://blenderartists.org/t/flexi-bezier-tool/1168179
Use bezier tools to layout the curves and curves to mesh to create the surface
Curves to mesh
https://blendermarket.com/products/curves-to-mesh
Select a row of vertex and create a curve to reshape the mesh with fall off.
bezier-mesh-shaper
https://www.blendermarket.com/products/bezier-mesh-shaper
Edit polygons with only the left mouse button
PolyQuilt addon for Blender 2.8
https://blenderartists.org/t/polyquilt-addon-for-blender-2-8/1168918
Show messages:  1-19  20-39  40-59  60-79  80-95
