Smooth connection of compressed spheres
All  1-4  5-9
You can optimise the process alternating the sphere edges lineary to simplify the jonctions.
Then doing boolean as usually and then you could maximalize filet.
I use next the flow.
The smooth is maximal and Blobby is here...
9286.6 In reply to 9286.5
When possible using Flow like Phiro writes above can be very helpful because it can be a lot easier to build an initially straight and uniform piece. Then deform it into your final shape.
9286.7 In reply to 9286.5
@phiro: "You can optimise the process >alternating the sphere< edges lineary to simplify the jonctions."
EDITED: 10 Mar 2019 by MALA
In fact, if edges are not in junctions zone or are in simply relation perpendiculary, the filet could be bigger.
Added, a test of rendering... Blobby ring rendering... MOI3D modeler and OWLET renderer.
Thanks to PILOU for finding OWLET, this render software is easy and gives spendid pictures...
EDITED: 10 Mar 2019 by PHIRO
Size: 197 KB, Downloaded: 42 times, Dimensions: 800x600px
9286.9 In reply to 9286.8
Owlet: It's not me! ;)
Last times I see it, it was here! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9275.5
and the first time in the forum here
https://moi3d.com/forum/index.php?webtag=MOI&msg=8034.1
Show messages: All  1-4  5-9
