Sort of parametric operation needed
All  1-3  4-9
9279.4 In reply to 9279.3
And make a triangle then make a Sweep 2 Rails ?
9279.5 In reply to 9279.4
Hello Pilou,
maybe you can check DesignSpark also.
I use SpaceClaim and there it is possible.
https://youtu.be/I7wDPaSEa9k
A nice day to all
Karsten
9279.6 In reply to 9279.5
Ah yes the fabulous Design Spark Mechanical( the SpaceClaim light)
makes that! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
Blue face is the Plan of rotation, here with 2 edges selected
EDITED: 7 Mar 2019 by PILOU
In Moi you can make an Extrude with Tappered angle!
Seems curioussly Tappered function works only on a Face(s) and not on just edges lines alone ???
With other extrude yes (Normal Extrude, To Point, Path )
9279.8 In reply to 9279.7
Extrude tapered works on curves as long as they form a closed planar shape.
If you have just one single line for example, that won't work.
9279.9 In reply to 9279.8
Thx for the explanation of this little mystery for me! :)
Show messages: All  1-3  4-9
