Beginner questions
All  1  2-8
9275.2 In reply to 9275.1
I am affraid that you can't make that now inside Moi!
The more easy and funny prog for that is SimLab Composer.
a free version is existing for Real Time and Normal Render (max 1920 * 1080)
Advantage you can mix any 3D Formats - little Primitives Basic Modeling - export in owner's 3D for reload your work!
For export Moi's objects don't take the 3DM format but OBJ + triangles or Ngons
http://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
Pro versions for objects' animation or more advanced functions (simulations, VR etc)
Here with the free version!
Moi Tuto express
Render SimLab Lite (2 sec)
EDITED: 5 Mar 2019 by PILOU
9275.3 In reply to 9275.1
Hi Jack, yes like Pilou says Simlab Composer would be a good one for you to check out. They even have a free version that should work fine for rendering. For animating you'd need the animator version but it's not very expensive.
To transfer your model from MoI to Simlab Composer, export to .obj format and set the option for "Output: Quads & Triangles".
You can do the material assignment part in MoI before the export if you want by assigning styles to your objects. Then in Simlab composer you will have a materials list that comes from your MoI styles list.
9275.4 In reply to 9275.1
Also another one that is very easy to use is KeyShot but it's more expensive.
9275.5
you could try this for starters ..
https://boxshot.com/owlet/
..to get yourself acquainted with the whole rendering business.
9275.6 In reply to 9275.5
Owlet Works like a charm!
9275.7 In reply to 9275.4
"Also another one that is very easy to use is KeyShot but it's more expensive."
yes it's expensive but it's the best way ;)
9275.8 In reply to 9275.7
Don't forget the super powerful Blender 2.8
Its material system, both Cycles and Evee, its absolutely stunning and highly customizable.
And it has a very powerful integrated rendering composition environment.
And it's COMPLETELY FREE!!
FREE.
Don't need to say anything more :)
Show messages: All  1  2-8
