V4 beta Feb-27-2019 available now
 1-16  …  137-156  157-176  177-196  197-216  217-218
9266.177 In reply to 9266.174
Hi Pilou, yes that's the problem area, it will be ok in the next v4 beta though.
9266.178 In reply to 9266.175
Hi Larry also I should mention that I'm hoping that the next v4 beta will be the last one and after that I'll switch to a very conservative mode trying not to make any more changes if possible to avoid introducing new bugs for the final v4 release. So if you have any other .3dm files that don't come across well now would be the time to send them to have a chance at getting them fixed for v4.
So far it seems that CAD exchanger .3dm transfer is working well other than this one particular bug though.
> About that, will the release 4.0 version need to be installed over 3.0, in the same folder? As an add-on
> or expansion of sorts? Or will it be a separate installation?
It's meant to be a separate installation, it's best not to try and install it directly in the same folder as v3.
> If it comes as a separate installer which can be installed in a separate folder, if I install it over V3
> would it retain the plugins I installed?
I'm not quite sure what would happen. It's best not to try and intermingle a v3 and a v4 installation directly over top of each other in a single install folder. It's intended that v3 and v4 should be in separate folders. Probably what would happen is you would have a v4 that worked and the current v3 installation would be broken. Many of the binaries for v3 and v4 have the same file name like MoI.exe, etc... so if you tried to put them in the same folder the v3 ones would get overwritten.
For plugins, most plugins are installed by copying them into the commands folder, you would just copy those from v3's commands folder into v4's commands folder. Also v4 now supports an additional commands folder located in appdata, outside of the main installation folder. It's good to put plugins there instead because then future versions will find them them there instead of needing to copy them around.
9266.179 In reply to 9266.178
Hey Michael!
It doesn't look like I have any more models which don't import correctly either as .step files or as .3dm files, after conversion with CAD Exchanger. From what I can tell, it looks like I'll be able to reliably use this pipeline going forward.
Thank you!
Best regards,
Larry.
9266.180 In reply to 9266.179
Thanks Larry, that's great!
9266.181 In reply to 9266.180
Hey Michael!
Me again, just came across another .step model that doesn't import correctly as Rhino 5 .3dm in MOI 3.0. What's unusual is that the .step file appears to import correctly.
I'm fairly sure this is fixed in the latest beta of 4.0 but just thought I'd report it anyway.
Thank you!
9266.182 In reply to 9266.181
Hi Larry, thanks for sending it. Yes that is indeed another case of the same bug and it will come in ok now in the next v4 beta.
9266.183
Will the next Beta contain the dimension tools?
9266.184 In reply to 9266.183
Hi Rudl,
Yes!
9266.185
Hi to all a think this was asked before but with upcoming version a figure out if planed a script or a new command to develop surfaces inside moi like Rhino here https://wiki.mcneel.com/labs/devsrf
thanks..
9266.186 In reply to 9266.185
It seems a lot like LineWeb.
Maybe some of the new crv methods of MoI4beta could be adapted...(?)...coplanar tangents...
9266.187 In reply to 9266.185
Hi pafurijaz,
Sorry no there are not currently any plans for developable surface focused tools in MoI. I would recommend using Rhino for those particular tools.
9266.188 In reply to 9266.187
Hey Michael!
Hope it's not too late for the next beta but I've found another model of mine which MOI 3.0 seems to have trouble with and it's different enough from the previous ones that I think it might possibly be a different bug than the one already addressed. So I thought I'd upload it here so you can maybe test the latest 4.0 beta with it as well.
I provided the problem model in .sat, .step and .3dm (Rhino 5) format in the attached archive file. Can you please test this .3dm as well? I promise I'll stop bugging you afterwards :)
Thank you!
Best regards,
Larry!
9266.189 In reply to 9266.188
Hi Larry, thanks for sending it in, it is indeed a different bug than the other one. Actually it's 2 bugs, the first one is in display mesh generation and the second one was in the same area of code as that previous bug but in a slightly different thing.
The display mesh bug is the one that looks like this:
So the problem is if this edge here is not refined with enough points:
It's going to cross over the inner boundary like this:
That one will go away during mesh export if you use a tight enough angle like 6 degrees or lower. This one is pretty difficult to fix because it would involve testing a lot of edges against each other to see if they intersect or not which would be a major performance degradation in display mesh generation. In the future maybe I could try something like only do that additional testing if the mesh was damaged. But it's basically a display artifact and the actual model is ok there and will also be ok during mesh export using a tight enough angle. Even without a tight enough angle the export mesh doesn't leak out so badly and the damage is contained just to that small area. So I'm not expecting to fix this one in v4.
All the other messed up areas are from the 2nd bug which I've fixed for the next v4 beta so in the next beta the export will look like this:
:) It's not any problem at all in fact I really appreciate you sending them in so I can get them fixed in v4! If you run into any more please go ahead and send them. If it's more convenient you can e-mail them to me at moi@moi3d.com .
MoI itself does not happen to write out .3dm files with the thing that involves these bugs, that's why they've stayed hidden for quite a while.
Thanks, - Michael
9266.190
With PDF export is it possible to control line widths for export - please find same file exported to PDF on MOI3 and MOI4.
Have checked INI file but not sure where to make changes.
thanks
Alex.
EDITED: 23 Dec 2023 by ALEXPOLO
9266.191 In reply to 9266.190
Hi Alex, yes when exporting a solid where it will create a hidden-line drawing, it is possible in both MoI v3 and v4 to control the line widths by using the "Line style options" button in the PDF export options dialog:
Then on the "Line style options" dialog, the widths are controlled by this column here:
It appears that your v4 export is using the default values while your v3 export has had them modified.
Did you do the v3 and v4 export from different machines though or from the same machine? If it's on a different machine then you would want to modify your v4 settings to match what you have on v3. If it's on the same machine that might be some kind of bug since the values should be coming from the same section in moi.ini for both v3 and v4.
If you want to sync up 2 moi.ini files, you would copy over the [AI/PDF Export] section from your v3 to your v4.
9266.192
Thanks again Michael - sorry on my part for missing the obvious I presumed the Line Style Options Box was referring to the tick boxes above and never clicked on that. All AOK your in depth support is priceless.
regards
Alex.
After my recent re-install to SSD drive:
The moi.ini file is in the appdata directory, and is being used by both MoI3 and MoI4Beta, which is a problem when trying to use the same hotkey
for nodeeditor for both MoI3 and MoI4Beta.
I see on my old laptop, which lacks V4beta, that MoI3 saves moi.ini to %appdata%.
So on my main SSD drive computer, I have only Moi directory in appdata. Maybe I need Moi3 and Moi4beta directory there?
EDITED: 23 Aug 2019 by BEMFARMER
9266.194 In reply to 9266.193
Hi Brian, probably the easiest solution would be to make the shortcut key do different things depending on the MoI version that it is running inside of.
That would be like this:
script: if ( moi.majorVersionNumber == 3 ) { moi.ui.alert('running in v3'); } else if ( moi.majorVersionNumber == 4 ) { moi.ui.alert('running in v4'); }
Then that way you don't have to have separate moi.ini files just to have that one thing different.
If you do want to have separate moi.ini files there are a couple of ways to do that.
One is to move the moi.ini file to be in the install directory in the same location as MoI.exe . If MoI finds a moi.ini file there it will use that instead of getting it from %appdata%\moi . However, by default Windows restricts programs running at a regular privilege level from modifying the contents of the Program Files directory so you would need to run MoI at an elevated privilege level for it to be able to save your settings out. You would do that by setting the "Run as administrator" option in the properties of the shortcut you use to launch MoI.
Then the other way is that you can pass the path to a moi.ini file to MoI.exe as a command line parameter, putting " " around it if there are any spaces in the path. When MoI.exe is given a command line parameter that ends in ".ini" it will use that as the .ini file for reading and writing settings. You could have it in the regular appdata folder and name it moiv4.ini for example.
Hope that helps!
9266.195 In reply to 9266.194
Thank you Michael.
2nd method, v3 Moi.ini in same folder as v3 Moi.exe, with admin. priv. in icon key for MoI3 works well, but it is necessary to use admin. priv. for each reboot of Windows 10.
v4Beta Moi.ini still good in %appdata%
I'll look at the other methods...
9266.196
Hi Michael.
Is there way to Export Selected only geometry (I'm exporting to OBJ)?
I'd just like to pick some surfaces and export only those instead whole model or instead hiding parts i don't want to export first.
If there is not such thing please consider it as feature for v4 :).
EDIT: Ignore my message, I'm an idiot, i've not noticed those 3 yellow rings on Export button :) :).
EDITED: 24 Aug 2019 by LEWIS3D
Show messages:  1-16  …  117-136  137-156  157-176  177-196  197-216  217-218
