V4 beta Feb-27-2019 available now
 1-4  …  65-84  85-104  105-124  125-144  145-164  …  205-218
9266.105 In reply to 9266.104
Object snap was on (with point snap on). I was trying to move (by dragging) the ending points of a |_| to form a triangle, but the snap does not "see" points. Using move command solves it though! I just found it curious that it would detect every potential snap axis/point except for the points of the line while I moved a point around.
Thank you for your very thorough answer! :)
EDITED: 28 Mar 2019 by NAMELESS
9266.106 In reply to 9266.105
Hi nameless, there are some kind of odd effects when dragging points when snapping to the object's own self. Stuff like the starting point kind of getting stuck in place and just tending to stay stuck on its own shape rather than being freely movable.
It would probably make sense to make an exception for the other end of an open curve though.
9266.107 In reply to 9266.106
I think that behavior would be more intuitive, somehow you expect to be able to close a curve by dragging the ends.
It remains amazing to me how you have limitless energy and an open ear to all feedback. MoI has a very loving father :)
9266.108
Hi everyone, I wanted to do a conversion test in NURBS surfaces this 3D scan(https://www.thingiverse.com/thing:1415162), I used Blender to generate the square topology with the remesh modifier, then I exported to OBJ and I created a new mesh using a free app Instant_Mesh to generate a smaller file 21.9MB (21.882.962 bytes), finally I imported in Moi3D to generate the NURBS surface from the square mesh obj model, the conversion was successful but the resulting file is huge, unmanageable, to be used too heavy 1.6GB (1.564.648.052 byte)
Below the zip file contain the file use for the NURBS conversion.
EDITED: 4 Nov 2021 by PAFURIJAZ
9266.109 In reply to 9266.108
Hi pafurijaz, thanks for testing it! It is not really expected that such a highly detailed and heavy mesh would give a manageable result, it would need to be significantly simplified for that.
The main focus of the converter is to give a highly accurate result, it's really more intended to enable getting a smooth and accurate conversion from a light sub-d cage so that can be used as a base shape for further NURBS modeling.
Conversion of 3D scanned data really needs a more specialized tool that is focused entirely on that process, it is not a specific focus area of MoI's converter.
That being said it is good to see some "torture testing" of it as well!
I make the same with your file (used Zbrush Decimation Master 10% - gives me a file OBJ 1 .5 megas )
But subdiv in Moi gives a 3dm quasi 1 Giga ! (980 megas) not manageable on my Latop! (just following)
https://www.filehosting.org/file/details/790793/Rhino_scan_remk.zip (file 3dm of 980 megas)
with Decimation Master 5 % gives a file OBJ 660 KB for a 3dm of 450 Megas!
https://www.filehosting.org/file/details/790794/Rhino_scan_remk660.zip (file 3dm of 450 megas)
More easy! Just following!
EDITED: 31 Mar 2019 by PILOU
Even with a very big decimation (0,5 %)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/rhino_scan_rem05.zip
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/rhino_scan_rem5.obj
(unzip = .3dm of 44 megas for an .obj of 660 KB)
Boolean Operation takes some times! A Boolean Diff with a Simple Sphere takes 20 sec! ;)
Does it the same for you ?
EDITED: 2 Apr 2019 by PILOU
Even with a big decimation here in Zbrush Decimation Master (0.5 % )
Operations after importation by subdivision take some times! :)
Boolean Diff a simple sphere takes 20 seconds!
And Rhino is something like a Pompom's sculpture! :)
9266.113 In reply to 9266.112
try Instant Meshes! (https://igl.ethz.ch/projects/instant-meshes/)
I exported an obj of around 8K polygons, pure quad mesh with a file size of 3.5MB. Imported nicely into Moi3D.
3dm file was around 88MB but it looks clean and i can boolean diff a sphere in 10-15 sec on my MBP :-)
Playing with different polygon counts is easy in Instant Meshes so give it a go!
Dinos
Size: 200.5 KB, Downloaded: 152 times, Dimensions: 1762x1748px
Size: 440 KB, Downloaded: 173 times, Dimensions: 1830x1828px
9266.114 In reply to 9266.113
I took your OBJ file and run it inside Zbrush for decimate it! ;)
And I suppose the Zbrush Decimaster has same functions than Instant Mesher! ;)
It's more that problem : I have only 8 Gigas ram on my Latop!
And seems I have same time consuming for boolean function than you! ;)
Ps Have you a direct link for download an Instant Mesher windows version ? Because I am a little losted over all these files!
(without line command if possible! :)
Else 8 years old! ;)
9266.115 In reply to 9266.114
Sure, you can download it from the github page: https://github.com/wjakob/instant-meshes
Its fast and efficient and should run nicely on your computer.
It even has a really nice UI to play with :-)
Dinos
9266.116 In reply to 9266.111
This is probably because of the relatively high face count in the model. Your model appears to be made up of all triangles instead of being a quad-dominant mesh set up for sub-d smoothing. So because of that you're getting a lot of little tiny faces.
The sub-d importer is primarily focused on converting sub-d models, not non-sub-d triangle mesh models like you are using there.
9266.117 In reply to 9266.115
Thx but the direct link for Windows all in one Standalone was a little more following! ;)
After some clicking I finally found it! :)
https://instant-meshes.s3.eu-central-1.amazonaws.com/Release/instant-meshes-windows.zip
9266.118
Probably been asked before tried to search but couldn't dig anything up - is there a way to set BROWSER - Object / Types / Styles to be rolled out permanently on starting a new doc - find its a repetitive function that I do with new docs in MOI.
9266.119 In reply to 9266.118
Hi Alex, it is possible in v4 to have scene browser items expanded on program launch by making a startup script as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9157.2
9266.120
thanks Michael works great.
9266.121
Hi Michael, any very rough timeline on the next beta release? I hate to be that guy, but I would love to have something exciting to look forward to :)
9266.122 In reply to 9266.121
Hi nameless, re: next beta release - well I'm heading out on vacation for a week. Maybe something like 3 weeks from now?
I've been making progress on basic dimension annotations but it still needs some more work.
9266.123 In reply to 9266.122
I wish you fun and relaxation in your vacation! And looking forward to it :)
Out of curiousity, I've been checking the contents of a few folders. :-)
In the MoI4.0_Beta_Feb-26-2019, commands folder, I have 267 "stock" command related files, (<50% .htm, and> 50% .js).
In the %AppData" / Moi/Commands folder, I have 1089 files. There are 266 "stock" command related files (more or less duplicates of the MoI4.0_Beta commands folder (-1)).
(I thought that the "stock" commands were supposed to be in the beta/commands folder, but at present they are in both locations.)
There are 823 additional "add-on" files, with _underline prefix, (<50% .htm), including quite a few experimental commands, and "mod" versions.
So one question is, in which directory do the "stock" MoI commands belong? Did the last update put the "stock" commands in the %AppData% Commands subdirectory?
Show messages:  1-4  …  45-64  65-84  85-104  105-124  125-144  145-164  165-184  …  205-218
