V4 beta Feb-27-2019 available now
 1-2  …  63-82  83-102  103-122  123-142  143-162  …  203-218
9266.103
Hey friends! I hope everyone is having fun and being creative!
I got some time to model with the latest beta again :)
I notice that when manipulating the points of an open polyline, I get no snap when moving the ends. There is no snap to point behavior when I move a point. Have I turned something off or this is normal?
9266.104 In reply to 9266.103
Hi nameless, it is normal that moving a polyline point will not snap to itself while dragging points but you can use the Transform > Move command if you need to do that.
If that's not it then it sounds like you have turned "Object Snap" off. It is controlled by this button in the bottom toolbar:
If that is not highlighted in orange click on it to turn it on.
It is also possible to disable specific types of snaps, that is done by clicking on the little arrow above the Object Snap button that will appear when you move the mouse over it. A menu will pop out where specific snap types can be disabled so you might see if you have unchecked any of those previously:
9266.105 In reply to 9266.104
Object snap was on (with point snap on). I was trying to move (by dragging) the ending points of a |_| to form a triangle, but the snap does not "see" points. Using move command solves it though! I just found it curious that it would detect every potential snap axis/point except for the points of the line while I moved a point around.
Thank you for your very thorough answer! :)
EDITED: 28 Mar 2019 by NAMELESS
9266.106 In reply to 9266.105
Hi nameless, there are some kind of odd effects when dragging points when snapping to the object's own self. Stuff like the starting point kind of getting stuck in place and just tending to stay stuck on its own shape rather than being freely movable.
It would probably make sense to make an exception for the other end of an open curve though.
9266.107 In reply to 9266.106
I think that behavior would be more intuitive, somehow you expect to be able to close a curve by dragging the ends.
It remains amazing to me how you have limitless energy and an open ear to all feedback. MoI has a very loving father :)
9266.108
Hi everyone, I wanted to do a conversion test in NURBS surfaces this 3D scan(https://www.thingiverse.com/thing:1415162), I used Blender to generate the square topology with the remesh modifier, then I exported to OBJ and I created a new mesh using a free app Instant_Mesh to generate a smaller file 21.9MB (21.882.962 bytes), finally I imported in Moi3D to generate the NURBS surface from the square mesh obj model, the conversion was successful but the resulting file is huge, unmanageable, to be used too heavy 1.6GB (1.564.648.052 byte)
Below the zip file contain the file use for the NURBS conversion.
EDITED: 4 Nov 2021 by PAFURIJAZ
9266.109 In reply to 9266.108
Hi pafurijaz, thanks for testing it! It is not really expected that such a highly detailed and heavy mesh would give a manageable result, it would need to be significantly simplified for that.
The main focus of the converter is to give a highly accurate result, it's really more intended to enable getting a smooth and accurate conversion from a light sub-d cage so that can be used as a base shape for further NURBS modeling.
Conversion of 3D scanned data really needs a more specialized tool that is focused entirely on that process, it is not a specific focus area of MoI's converter.
That being said it is good to see some "torture testing" of it as well!
I make the same with your file (used Zbrush Decimation Master 10% - gives me a file OBJ 1 .5 megas )
But subdiv in Moi gives a 3dm quasi 1 Giga ! (980 megas) not manageable on my Latop! (just following)
https://www.filehosting.org/file/details/790793/Rhino_scan_remk.zip (file 3dm of 980 megas)
with Decimation Master 5 % gives a file OBJ 660 KB for a 3dm of 450 Megas!
https://www.filehosting.org/file/details/790794/Rhino_scan_remk660.zip (file 3dm of 450 megas)
More easy! Just following!
EDITED: 31 Mar 2019 by PILOU
Even with a very big decimation (0,5 %)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/rhino_scan_rem05.zip
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/rhino_scan_rem5.obj
(unzip = .3dm of 44 megas for an .obj of 660 KB)
Boolean Operation takes some times! A Boolean Diff with a Simple Sphere takes 20 sec! ;)
Does it the same for you ?
EDITED: 2 Apr 2019 by PILOU
Even with a big decimation here in Zbrush Decimation Master (0.5 % )
Operations after importation by subdivision take some times! :)
Boolean Diff a simple sphere takes 20 seconds!
And Rhino is something like a Pompom's sculpture! :)
9266.113 In reply to 9266.112
try Instant Meshes! (https://igl.ethz.ch/projects/instant-meshes/)
I exported an obj of around 8K polygons, pure quad mesh with a file size of 3.5MB. Imported nicely into Moi3D.
3dm file was around 88MB but it looks clean and i can boolean diff a sphere in 10-15 sec on my MBP :-)
Playing with different polygon counts is easy in Instant Meshes so give it a go!
Dinos
Size: 200.5 KB, Downloaded: 167 times, Dimensions: 1762x1748px
Size: 440 KB, Downloaded: 192 times, Dimensions: 1830x1828px
9266.114 In reply to 9266.113
I took your OBJ file and run it inside Zbrush for decimate it! ;)
And I suppose the Zbrush Decimaster has same functions than Instant Mesher! ;)
It's more that problem : I have only 8 Gigas ram on my Latop!
And seems I have same time consuming for boolean function than you! ;)
Ps Have you a direct link for download an Instant Mesher windows version ? Because I am a little losted over all these files!
(without line command if possible! :)
Else 8 years old! ;)
9266.115 In reply to 9266.114
Sure, you can download it from the github page: https://github.com/wjakob/instant-meshes
Its fast and efficient and should run nicely on your computer.
It even has a really nice UI to play with :-)
Dinos
9266.116 In reply to 9266.111
This is probably because of the relatively high face count in the model. Your model appears to be made up of all triangles instead of being a quad-dominant mesh set up for sub-d smoothing. So because of that you're getting a lot of little tiny faces.
The sub-d importer is primarily focused on converting sub-d models, not non-sub-d triangle mesh models like you are using there.
9266.117 In reply to 9266.115
Thx but the direct link for Windows all in one Standalone was a little more following! ;)
After some clicking I finally found it! :)
https://instant-meshes.s3.eu-central-1.amazonaws.com/Release/instant-meshes-windows.zip
9266.118
Probably been asked before tried to search but couldn't dig anything up - is there a way to set BROWSER - Object / Types / Styles to be rolled out permanently on starting a new doc - find its a repetitive function that I do with new docs in MOI.
9266.119 In reply to 9266.118
Hi Alex, it is possible in v4 to have scene browser items expanded on program launch by making a startup script as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9157.2
9266.120
thanks Michael works great.
9266.121
Hi Michael, any very rough timeline on the next beta release? I hate to be that guy, but I would love to have something exciting to look forward to :)
9266.122 In reply to 9266.121
Hi nameless, re: next beta release - well I'm heading out on vacation for a week. Maybe something like 3 weeks from now?
I've been making progress on basic dimension annotations but it still needs some more work.
Show messages:  1-2  …  43-62  63-82  83-102  103-122  123-142  143-162  163-182  …  203-218
