Cutting along a curved surface
All  1-2  3-5
The Insert function is also some cool! :)
The trick is to click "Face(s)" and not "solid(s)"! (else function don't work)
here "Inward" + "Grooved" on the top face
Union Top and Bottom solids
then Shell the top Face + Fillets on some edges
(with the real time free Simlab Composer lite max 1920 * 1080)
EDITED: 25 Feb 2019 by PILOU
9264.4
Hi caldreemn
If you want to get some control over cut line position on the helmet, you can project a curve to the side. Since it will be a closed curve, split it in 4 pieces with trim points, so you get 4 sides for network (I highlighted front and back pieces). Add profiles roughly in the middle, they will define depth of the cut, my example is much deeper than on your model.
Narrow cut ("mouth") is obtained again from side projected curve, used as a rail for the sweep.
Hope this helps
CK
Size: 62.6 KB, Downloaded: 69 times, Dimensions: 810x547px
Size: 65 KB, Downloaded: 61 times, Dimensions: 1031x664px
Size: 56.4 KB, Downloaded: 74 times, Dimensions: 1027x666px
9264.5
Thank you for all the suggestions! I really appreciate the insights here!
Jason
Show messages: All  1-2  3-5
