Shrink+Join+Expand Script Question
All  1-4  5-8
9250.5 In reply to 9250.4
Hi Bravlin, yes in v4 there is a way to make shortcut keys that trigger UI elements in the command without having to click them.
To do a move with the bounding box center button triggered automatically set this up on a shortcut key:
move BoundingBoxCenter
9250.6
Its good that we have this option for a script automation.
But this mean that for each tool we need to reserve its own button for "bounding box center" option.
I guess it may be easier if we just press RMB after move tool invocation to activate bounding box center.
This way we do not need additional shortcuts.
If it possible of course.
9250.7 In reply to 9250.6
Hi Bravlin, sorry no right mouse button does a variety of things like a shortcut for "Done" or repeat last command if not in a command currently. There isn't any way to make it click the "Bounding box center" button.
It is possible though to set up a shortcut key script that will push the button on any command that is currently showing it.
To do that set up a shortcut key with this as the command on it:
script: moi.ui.fireUIEvent( 'BoundingBoxCenter' );
9250.8
Right the fireUIEvent ! That we use for adding trim points. Thanks Michael !
moi.ui.fireUIEvent( 'addtrimpoints' );
Show messages: All  1-4  5-8
