Line / Curve selection
All  1-6  7-12
9249.7 In reply to 9249.6
Hi Michael and Cody,
thanks for your input and advises how to easier select obstructed lines. The idea with colour group is great, I think I should also do that to have a better structure in my models.
The issue I have when I select with a selection window from left to right is that I cannot select if a surface is below. It is rather difficult then to select by moving the cursor and catching the lines I want to select. I would then have to ctrl+x the surface and once selected the area, I ctrl+v the surface back to its position. In general it is not a big issue, just something which could be considered as an improvement later, for example as Cody wrote to have an optional pop-up window only when pressing an additional key. But indeed Michael, MOI I found from the beginning very clean due to the not fully overloaded screen: here a docked window, there a pop-up and another undocked window I always need to shift from one side to another :)
Man, that dark grey UI is really great :-))
Cheers,
Axel
9249.8
Thanks for the compliment, Axel. The theme now has a new add-on to support Max Smirnov's Custom UI better. In case you use that mod, that is.
I'd rather have MoI's clean interface and work flow than a something like *cough* Blender *cough*. You'll figure out a work flow that suites your needs and it will become second nature after a short while. Once you've created a part, that might even use multiple colours, select it all carefully and give it a useful name. Then you'll always be able to hide and show it on a whim. Also, I typically model interior surfaces one colour and the exterior another. Then I can hide and show the shell and work on the interior stuff more easily and vice versa. I'll even duplicate full shapes before I do any boolean operations, just in case if I need to change the master shape after the fact and redo the boolean again. I put those "master" objects on their own colour so I can easily retrieve them, but keep them hidden while I work. Food for thought.
Thanks for the clarification on how to use filters, Michael. A powerful hidden feature. I like those. It's like when you've mastered the surface features of MoI, you begin to ask the right questions and, sure enough, you've got a solution already to go on these forums. By keeping these more powerful features hidden, you keep your software more accessible. It's a necessary evil and I love it.
There's a game design book called the A Theory of Fun. It postulates that fun comes from learning. When you play a game, it has to teach you something or reveal some new understanding in order to continue to be fun. I feel the same way about MoI. You can immediately start making stuff and mucking around, but there's more to it than meets the eye. When I learn how to do something else with MoI, it's typically really simple and then my learning brain parts are tickled and I find myself having legitimate fun while working with your software. Those Aha! moments are pure gold. I keep reading in these forums that people are having fun using your software... and I don't think it's quite as figurative as one might think.
-- Cody
9249.9 In reply to 9249.7
"""""The issue I have when I select with a selection window from left to right is that I cannot select if a surface is below. """"""
There is a key modifier that stops the "pick selection" that creates this interference.
I think it is "ctrl+shift" (not at my computer)
Then, only window selection works....
This can help in the situation you are describing...
9249.10 In reply to 9249.9
Thanks, BurrMan!
That was what I was trying to ask about earlier, but my memory was too vague to convey it properly. But now I know about custom filters AND turning off the auto-picking when mouse clicking.
And yes, it's CTRL + SHIFT.
-- Cody
9249.11 In reply to 9249.8
Hi Cody,
Thanks Cody! And yup this is the strategy for MoI. There are some good parts and bad parts to it. One of the good parts is it makes for a lower learning curve for beginners and helps a beginner move to an advanced user more gradually.
One of the bad parts is that often advanced users will take a quick look at it and decide "it's a toy".
Something that makes it work well is some stuff that benefits beginning users like having a streamlined workflow and less steps also benefits advanced users who value speed.
9249.12 In reply to 9249.9
Thank you!! That is another trick I use from now on and I am glad that I learned this today :-) I think with this and the other methods you gents brought up here in this thread I am fine regarding selecting hidden lines :)
Cheers,
Axel
Show messages: All  1-6  7-12
