stone
All  1-6  7-11
9247.7 In reply to 9247.1
9247.8
Thank you ... thank you all.
I'll have another try using sub-d. I have not previously tried it.
cheers,
eric
9247.9
What you could do is use the push/pull method.
Make a
- Sphere
- show points
- select different points and then push and pull them around to get a form that you prefer.
- if you need more variation you can then cut into those stones - boolean
- chamfer if needed.
For uvmapping you probably want to use tri-planar method in your chosen engine as there are no UV's. With a detailed height/displacement map to show details.
I have also added some Sub-D stones in the file. They took me a 5 mintues to create using procedurals as apposed to manual sculpting.
9247.10 In reply to 9247.9
Thanks Sam ...
Very helpful.
eric
9247.11 In reply to 9247.10
good idea
thanks
Show messages: All  1-6  7-11
