stone
All  1-4  5-11
About fillets you will have any problem to make them if you export in Step format to the free DesignSpark Mechanical ;)
Even with your "special" object! ;)
But it's a little tricky ;)
See my French site about that! ;)
http://moiscript.weebly.com/designspark.html
http://moiscript.weebly.com/designspark-1.html
or here for English people ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=6186.52
EDITED: 8 Feb 2019 by PILOU
9247.6 In reply to 9247.1
Hi eric, you might try some of these models with the new SubD importer:
https://www.turbosquid.com/Search/3D-Models/free/stone
9247.7 In reply to 9247.1
9247.8
Thank you ... thank you all.
I'll have another try using sub-d. I have not previously tried it.
cheers,
eric
9247.9
What you could do is use the push/pull method.
Make a
- Sphere
- show points
- select different points and then push and pull them around to get a form that you prefer.
- if you need more variation you can then cut into those stones - boolean
- chamfer if needed.
For uvmapping you probably want to use tri-planar method in your chosen engine as there are no UV's. With a detailed height/displacement map to show details.
I have also added some Sub-D stones in the file. They took me a 5 mintues to create using procedurals as apposed to manual sculpting.
9247.10 In reply to 9247.9
Thanks Sam ...
Very helpful.
eric
9247.11 In reply to 9247.10
good idea
thanks
Show messages: All  1-4  5-11
