stone
All  1-2  3-11
9247.3 In reply to 9247.1
Hi eric!
First thought in my head is that Zbrush would be a better tool for that, even if you want a very stylized result.
Now, for your specific situation, there are instances where fillet and chamfer will not complete successfully because of the specific geometry of your object. For example, for a fillet command to completely process a series of edges, it needs to have the necessary distance from nearby edges to create the circular profile. From my understanding (I am new to MoI) as things get more cluttered and geometry becomes more complicated, completing fillets on a whole object or even a series of edges becomes more difficult. Sometimes, merging edges (using the merge command) and picking small groups, or even selecting a specific surface might give you a better chance. When the fillet command fails to process your selection it sometimes creates a profile that with slight modifications can be booleaned or used as a trimming object so you can get something close to what you were going for. That's what you are seeing in your example.
Subdiv will work also with your start object but as it's not very adapted result will be not very suitable! :)
Depend of what do you want exactly and size of what is viewed! :)
With this yellow stone (yours subdivided post 1)
EDITED: 8 Feb 2019 by PILOU
About fillets you will have any problem to make them if you export in Step format to the free DesignSpark Mechanical ;)
Even with your "special" object! ;)
But it's a little tricky ;)
See my French site about that! ;)
http://moiscript.weebly.com/designspark.html
http://moiscript.weebly.com/designspark-1.html
or here for English people ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=6186.52
9247.6 In reply to 9247.1
Hi eric, you might try some of these models with the new SubD importer:
https://www.turbosquid.com/Search/3D-Models/free/stone
9247.7 In reply to 9247.1
9247.8
Thank you ... thank you all.
I'll have another try using sub-d. I have not previously tried it.
cheers,
eric
9247.9
What you could do is use the push/pull method.
Make a
- Sphere
- show points
- select different points and then push and pull them around to get a form that you prefer.
- if you need more variation you can then cut into those stones - boolean
- chamfer if needed.
For uvmapping you probably want to use tri-planar method in your chosen engine as there are no UV's. With a detailed height/displacement map to show details.
I have also added some Sub-D stones in the file. They took me a 5 mintues to create using procedurals as apposed to manual sculpting.
9247.10 In reply to 9247.9
Thanks Sam ...
Very helpful.
eric
9247.11 In reply to 9247.10
good idea
thanks
Show messages: All  1-2  3-11
