Question about flow
All  1-10  11-16
9246.11 In reply to 9246.10
Hi nameless, it's probably a file named MiniSidepane.js in your appdata\startup folder. Can you post that file?
9246.12 In reply to 9246.11
Yes! That was the file, I remember its name. Here it is!
9246.13 In reply to 9246.12
Hi nameless, it's a bug or intentional omission in the MiniSidepane.js script file - in there it is inserting all the new rearranged buttons in the sidepane and it just does not have a history button in the chunk of stuff it inserts. Probably because it would need an additional row for it?
Right now inside your Draw / Edit section, the last row contains Cone, Text, Join, and Separate.
If you want to add an additional row containing the History button, you would need to insert:
<tr><td><moi:commandbutton icon="icons/HistoryIcon.png" command="history"><moi:text textid="History" /></moi:commandbutton></td></tr>
On line number 11 of the script file.
But you need to insert that not at the very end of the string, it should go just before the </table> that's near the end.
The end of the string looks like this:
</td></tr></table>';
The target spot where you insert it is marked with the x here:
</td></tr>x</table>';
9246.14 In reply to 9246.13
Success! You are the best. :)
Now the Construct/Transform and SubD palettes are collapsed when the program starts. It's probably due to the extra line for the history button.
Size: 339.9 KB, Downloaded: 21 times, Dimensions: 1920x1200px
9246.15 In reply to 9246.14
Hi nameless, you're welcome! For the collapsed palettes does it make any difference if you unmaximize the window and make it fairly large in its unmaximized state, then exit and restart?
9246.16
YES! You know your child so well. :)) All systems green and warp drive ready.
Show messages: All  1-10  11-16
